q3 rattle noises
Hi All;
I own a 2015 facelift Q3 1.4 tfsi a
With a 6 gear Stronic
I have been hearing some rattle noises from the car.
I dont know if they are normal or not. I would be glad if you can share your toughts.
First of all, there is a rattle noise coming from gearbox on bumpy roads. I knew this issue from DSG7 but did not know 6 gear Stronic also have it. Is this normal or is there a problem?
Rattle 2:
This rattle noise comes when the car is in 2nd gear and while accelerating or right after accelerating. Or right after changing gear.
You can hear a rattle noise like "TIRRRRRRRR" between 3th and 6th seconds of the vide. You must really listen carefully.
As if the gerbox gets it self ready for the next gear but it is very noisy.
Rattle 3:
This is the third rattle. This haapens when the car is on load and rpm is low.
You can hear a metallic rattle. Clearly audible between 15 to 17 seconds.
Thank you for your help.
Rattle 2:
Rattle 3:
trip_conduit
A4 (B9 Platform) Discussion
01-08-2024 08:45 AM
Deez99
01-24-2007 05:58 PM
