Last edit by: IB Advertising
- Audi Q5 Why Aren't DLR's Working Properly<br>Guide to diagnose trouble and recommended solutions.
Q5 Daytime Running Light Problem??
I'm in day 8 of my 2010 ownership and I just noticed that during the day, when the low beams are off and the daytime running lights (DRL) are on, that when you activate the turn signal, the DRL on the signal side, turns itself off. Once the signal goes out, the DRL comes back on. However, when the low beams AND DRLs are on, the turn signal has no effect on the DRLs. I cannot think of any reason why this would work like this. Is this a defect?
Unfortunately, that is the way it is suppose to be. During the day, with DRL's on, corresponding DRL turns out with turn signal. Really annoying, I know. There is a software "fix" for it, but you have to find someone with the VDS software and correct cable. I had mine changed so the DRL's stay on all the time now.
When you say "find someone", you mean a dealer? Who else would be capable of making the "fix"? Also, is this something a dealer would be willing or capable of doing, or because this is the way it's supposed to work, they won't mess with it. Have you heard any rationale why Audi would have it work this way? Makes no sense. Could it truly be a bug in the VDS software?
Additionally, it's not something a dealer will likely do because that how it is designed to operate. Therefore, you either need to find a person in your area who has a VAG-COM, or purchase one yourself, to make the change.
http://www.ross-tech.com/
http://www.vagtoolfinder.com/
No, it's not something the dealer will do for you, because it is the way the car is programmed. It is not a big in the system. There are plenty of people who have the software and cable to do this (that's how I had mine changed). All they do is plug it in to the usb port in the car, open the program, and uncheck the box for the "winking DRL's". It took all of 30 seconds to do. If you do a search on this forum, you will find all kinds of information on the DRL fixes, as well as other "fixes". It is just the way the cars are programmed for North America. But it can be changed. Just not by the dealer.
Redneck Truck
10
12-05-2010 08:36 AM
DKelly3854
03-16-2002 09:27 AM
