Last edit by: IB Advertising
- Audi Q5 How to Replace Headlight Bulbs<br>Step by step instructions for do-it-yourself repairs.
Q5 Headlights Bulb Replacement
Hello,
I have a 2010 Q5 Premium with the standard halogen lights. I want to replace the bulbs with Höen Xenonmatch. I tried to remove the headlight assembly by removing the 3 torx screws, it moved, but I could not get it out. Looks like the whole front end would have to be removed to get it through. Is there an easier way that is not that obvious?
Thanks!
Thanks!
try PM to this guy if no one chips in and welcome to the board anyway.https://www.audiworld.com/forums/sho...09&postcount=1
After removing the 1 screw and 2 bolts, the assembly moves freely about 3 inches forward. But it cannot slide out through the front. The hole is too small. The top part hits the projection from the fender so the assembly cannot go up.
I got some help from a specialist. So in fact, the assembly does not need to come out completely. There is enough room once the 3 screws are removed to slide the assembly out 3 inches in order to open the 2 small trap doors and remove/replace the bulbs. They just snap in place. The passenger side is more work since the air filter assembly has to be removed.
webreid (06-27-2024)
Thanks for the info!
iinviktus
04-13-2010 03:46 PM
TwiceBlown
09-09-2002 04:59 PM
Boss Hogg
08-04-2000 04:06 PM
