[DIY Guide] Audi Q5 S-Line Grille Retrofit onto non S-Line Bumper (No Mods Required!)
#11
The honeycomb fog grilles only fits the S-Line bumper (shape is different). The rear honeycomb grille I believe only comes with the S-Line rear bumper.
I had a VW MKV GTI for the past 5 yrs before the Q5, thus I had enough of "honeycomb" on my car. I do like the styling of the S-Line front bumper, but not really feeling the honeycomb anymore.
![](http://i74.photobucket.com/albums/i251/chwang0129/Car%20Parts/IMG_1947.jpg)
#13
If I move to a State with license plate requirements (e.g. TX, VA), I will just replate the license plate filler/delete with a license plate bracket. The swap only takes 1 min. The S-Line grille stays regardless.
#14
Excellent write-up. Wife noticed an S-line grille the other day and really liked it, so I might be taking this on soon. If you don't mind me asking approx how much did the the new grille run you?
#15
Thanks for this guide c-dub,
I just changed my grill for an s-line grill using your guide and everythnig worked great. here is the result w/ honeycomb non s-line bumper (a bit more than 100 euros on ebay):
![](https://docs.google.com/uc?id=0B9-4449Da_xrcnZiN2NHLWE5UFU)
One notable difference is that I had PDC so here are the extra instructions for people in that case:
Altogether this is pretty straightforward, the first step is to unplug the connector that's on the upper-side of the grill:
![](https://docs.google.com/uc?id=0B9-4449Da_xrdFRxTTRzcm9JN3c)
Then you'll have to remove the little "holders" that hold the PDC wire around the grill on the inside:
![](https://docs.google.com/uc?id=0B9-4449Da_xrZW5uUjU5LXdGMzQ)
It's a bit of a pain to remove but doable.
Altogether this was pretty easy, the screws are not very tightly screwed and it's quite easy to screw/unscrew manually.
#17
#20
1 Post
Just completed my retrofitting of the S-Line Grill on the 2012 Audi Q5 and All credits goes to
1. C-Dub DIY Guide to S-Line Grill retrofitting.
2. Nivco-PDC wire clip removal and reinstall guide.
3. Spijun-for the S-Line Grill Part numbers.
Audi should have just install the S-line Grill to all the Q5's....Considering what we paid for...
Here is the finish result on my 2012 Audi Q5 Monsoon Gray P-Plus models.
psiked (03-12-2024)
