2013 Q5 Lift Gate Doesn't Close on First Attempt
When pressing the button to close the lift gate, it starts to close for a second and then stutter-stops and raises back to fully open. If I hit the button a second time it usually closes without issue but sometimes it will require a third attempt.
I haven't really noticed a pattern about it yet, but it seems to happen 90% of the time I try to shut the lift gate and it's been happening for about 2 weeks now. To top things off I JUST took my Q5 in for it's 5K service right before this issue showed up. Arg!
At any rate, I've been using the cargo area a lot more as of late for my dogs and softball and stuff, so I'm not sure if that's partly to blame but it's definitely proven that it's a recurring issue and not a one off thing.
The only reason I haven't gone immediately back in for service is because it's a huge hassle to take it to my busy dealer due to distance and their operating hours/availability. Plus their shuttle service is only offered once an hour regardless of circumstances. So if your appointment is at 8:10, you have to wait 50 minutes before the next shuttle at 9. So I'd rather not take it in if I can avoid it but obviously if it's the only answer, I'll just have to suck it up and take it in.
Anyways, I was hoping it's something simple that others know how to fix without needing dealer assistance.
Any help or advice is appreciated. Thanks a lot.
I guess, start with the simplest things first. Is it possible that something is caught in part of the mechanism? Obviously, something is triggering the safety return system, as if it thinks something is caught in the path of the door. Maybe some leaves, or something random from using it a bunch with your dogs?
nanotech
08-15-2005 02:19 PM
Arctic Ultrasport
NorCal Discussion
01-25-2005 10:43 PM
Keith2
02-03-2000 03:49 PM
