2014 Q5 -TDI hitch - not from factory
#11
The sensors are like little radar beacons. Anything in close proximity of a sensor will engage the audible alarm. I'd bet one of those bicycle wheels would do the trick. As a point of information, I can lay my road bike on its side inside the Q5 with the rear seat backs down. It's a 54cm frame. Maybe you can find a hitch mounted rack that will hold your bike(s) high enough as to not set off the sensors.
#13
The sensors surround the vehicle, so while the front sensors may be far or close you wouldn't know, because the tone would be a solid scream due to the bike rack proximity alerting the rears.
All this is moot though if there's some way to disable the rears if the hitch outlet is activated somehow (eg. like towing) and/or if the rack is out of the way enough as to avoid causing detection.
#14
Isn't there a graphic on the MMI screen? Swear I saw it during my test drive. Anyway, I'll probably be installing the Curt hitch because I plan to use it for bikes and skis occasionally, so OEM hitch cost is tough to swallow.
#16
I wish there was a way to drive to Houston (my closest) port of entry an pay for the install w/o using the dealer, 2k for a hitch is just crazy specially since its installed at the port.
Pedro
Pedro
#17
SparTTan
10-12-2006 05:13 PM
stilljester
06-05-2005 05:19 PM
4LinkS4
09-07-2001 09:08 AM
