2014 SQ5 Winter Tires
If you need true winter tires your only real option in 21" is Pirelli scorpion winter which is roughly $1400
For slightly less money I ordered a 19" wheel set with 255/50/19 Pirelli Scorpion winters mounted and balanced from Tire Rack. ($1297) They have this particular tire in this size on closeout for a steal.
I'd look for either a 19" rim/winter tire combo brand new and swap every season with your 21" on summers, or maybe look for some used OEM 19 or 20" with winters already on them for sale locally to you.
Having a full winter/summer set of rims and tires is a bigger initial investment, but you have to keep in mind each set is only going to see about 6 months of use annually, so you'll get a lot more time out of the tires before they need replacement. I'm guessing it's going to be 3 years before i need to get new summer or winter tires based on the wear on them from last season.
As mentioned there just isn't a lot of selection out there for 21" and they are expensive.
Not with the SQ5. The TPMS sensors are on the hub, not in the wheel. I agree the 21" wheels look great, however it is nice in the winter to have to meaty tires to absorb potholes etc. The Pirelli Scorpions are not as aggressive as some other snow/ice tires however with quattro they work great and have the best dry performance.
If you really love the 21 look, then i'd either shop for another set of used 21 OEM rims and make them your winter set, or shop for a nice set of 21 summer rims and turn your OEM 21's into your winter set. I had OEM 20's on my SQ5 and i made them my winter set then bought myself another set of 20" summer rims (i'm not a fan of 21's).
you need -1 or -2 wheels for winter
my summer is 20" . my winter is 18"
go online to find a tire calculator to determine to correct ratio when changing wheel size. this is critical to ensure the tire turn at the same rate as the old ones
ie wheels that are 1 -2 inch smaller, that reduce the tire width as well which gives you more traction.
in winter the wider the tires, the less force / sq inch, thus less traction.
skinny winter tires are much safer that wider tires
PLUS
as a bonus your tires and wheels last longer as you now use two sets each year.
PLUS
