3.0T A6 vs 3.0T Q5, Any thoughts?
I noticed Q5's 3.0T achieves peak torque and horsepower in slightly lower RPM when compared to the A6 3.0T per Audi USA site.
I understand it's the exact same engine, and it is slightly detuned in the Q5 so the product does not overlap each other.
However, does anyone think it's essentially the exact same output it's just Audi's marketing trying to separate the two on paper only?
I suspect.
I also understand detuning is just a slightly modify computer program that's all. I wonder if there were some benefits when they decided to detune the Q5 3.0T, whether for MPG or something else.
I know it's a fast car still but just chips away at me thinking I could have the A6's fastness.
I suspect.
Well, part of it may be to separate products. But with an SUV you want power lower in the range, especially if you are to drive it in rougher situations like snow.
But even the A6's 3.0T is slightly detuned from the one in the S4.
If you want to power it up Parsec is right chipping it is probably your best option.
Audi has several engines 3.0 TFSI with different power:
- 3.0TFSI 200kW (272 HP)
- 3.0TFSI 213kW (290 HP)
- 3.0TFSI 228kW (310 HP)
- 3.0TFSI 245kW (333 HP)
- 3.0TFSI 260kW (354 HP)
Example
Company has the ABT chip tuning:
3.0 TFSI 228 kW (310 HP), 440 Nm to approx. 301 kW (410 HP), 540 Nm
or
3.0 TFSI 245 kW (333 HP), 440 Nm to approx. 320 kW (435 HP), 520 Nm
Example
or
I suspect.
I suspect.
You can see an interesting journey over the years, with Nissan's famous VQ motor. It's roughly the same block (3.7 as opposed to 3.5) as it has been for decades. But in the Infiniti G cars, it has steadily climbed in HP. Only about six-years ago, they were getting about 250hp at the crank. However, it's now pushing at least a solid 330. That's a HUGE jump. However, consequently, the torque has suffered (quite a bit, IMHO). It's lower peak than ever, and it comes quite high in the rev range. So, the modern G cars really need to be wrung out, to get the best.
I think you're overlooking some very important points. It might be the same basic block, head, and supercharger. But there are important differences to the intake, and especially the exhaust. It's not like they simply cross-fit the entire system from the A6 to the Q5. So, forgetting anything about the ECU program, the exhaust system on an A6 is going to be a little more free-flowing, which will directly result in higher HP, and lower TQ. The Q is going to have a little more back pressure, which will keep HP numbers back, but will bring up higher peak TQ, lower in the rev range.
idk what we're getting at though. Any N/A needs to be wrung out to get the most of it.
Having owned a 2003 G35 I can tell you lots about this engine. The VQ35DE was used across most of Nissans lineup, including the Pathfinder which had a torquier tune and less power. The VQ35DE which put out 260 horsepower in the G35 & Maxima, 245 in the Altima (I think, 255 Altima SE-R), it also did 280 in the G35 coupe and 285 in the 350Z. Before they increased displacement, stock form, the VQ35DE HR with dual intakes used in second gen G35's and late model Z33 350Z's had 300-305 horsepower. Not a very smooth engine at all, Audi's 3.2 is MUCH smoother and linear. The VQ was very rough, lots of torque and not very smooth.
They've finally smoothed things out in our '09 G37. It still has too little torque, and too high in the rev range, but the motor is much more smooth than the G35 we had. And that extra HP up top is quite exciting, especially when you drive around in manual mode with the paddle shifters. But the lump of low torque in the Audi is the winner. It reminds me of my old STi, because it comes in so low, and the AWD just claws off the line. NA & AWD is the best when it comes to a car driven mostly in the city.
Those motors pull hard and are great uptop so much initial tip in and great throttle response.
You are right about the Audi, that 3.2 despite having less torque, it was so much more accessible throughout the power band.
thehaviet
A6 (C7 Platform) Discussion
76
09-19-2016 03:58 PM
Tongpo~Dr. Evil
27
01-13-2004 01:09 PM
Gerry
13
12-09-2002 11:18 AM
