A6 wheels to Q5
A6 and Q5 have the same:
66.5mm center bore and 5x112mm
Some models have different ET
- A6 ET 43-45
- Q5 ET 33-39
- A6 ET 43-45
- Q5 ET 33-39
If you really like the A6 wheels, you can put some spacers between the hub and the wheels. I could recommend ECSTuning.com which has a comprehensive line of spacers. You may want to mount the wheels on the vehicle first, then determine how much desired space to move the outside edge of wheel to the fender. If you do this you need both the spacers and appropriate longer wheel bolts.
rayjr13
10
04-12-2016 04:43 PM
Quetzal
Wheels & Tires Discussion
09-23-2015 07:50 PM
cm09578
09-22-2015 06:38 AM
mkirkpatrick
09-03-2015 08:31 AM
