Anybody else bust off the sun visor hook?
#22
In my case it is not the hook that broke, but the little plastic cylinder that goes over the rod that goes into the hook.
I've been trying to find a replacement without success. Anyone knows what is the part number for it?
Thank you
Martin
Thank you
Martin
#23
#24
Unfortunatly it looks like the little plastic thing comes with the whole sunvisor... Oh well... I will continue my search.
Martin
#25
Audiworld Senior Member
https://www.amazon.com/gp/product/B017CMJT8W/
It's not a perfect match, a bit larger overall. I'm 6'3" and can never use visors, because they limit my visibility to the end of the hood. Mine was broken off when someone else was driving the car.
#26
Well, the replacement parts from China arrived today 17 days after ordering.
The gray color is not anything like a good match. And there is no texture on the exposed plastic surfaces as with the OEM ones. This makes them look cheap.
Worse, the "cover" piece which expands the fastener does not "snap" over the inner "hook" unit, so it won't even stay put. Given this, I didn't even bother to see if it would fit on the vehicle or if the clip would actually retain the sunshade.
In summary, they are cosmetically inferior and functionally unusable. So, I'm out $3.30 for the three of them. Oh well.
Has anyone else had any luck with any other aftermarket offering? Or should I just put in an application for a second mortgage and go OEM...
#27
Bought a 2012 A4 B8 few weeks ago. Used the visor first time today to cover the side window and while putting it back, the hook snapped! Is this the German quality? We never had any trouble of this sort in our totaled 2002 EXV6 Honda Accord.
#28
For cars this expensive it seems like Audi would have redesigned such a simple part. After reading this thread it looks this design flaw should have been fixed years ago. I'm currently looking for my first Audi, Q5 2.0T or 3.0T or A6 2.0T. Any other design issues I should be aware of? Thanks.
#29
After contemplating a delivered price just under $32 for an OEM clip, I took a second look at the parts I ordered from China. I had never checked them out inside the car.
I found that they would be much too tight a fit for the visor to be inserted under the hook as intended. I also found that I was able to easily remove the little metal spring from one. Following that, it was still too tight a fit.
I then shaved and shaped the inside of the hook a bit with a 9/32 drill bit running backwards slowly. This provided a good shape to accommodate the visor.
Finally, I shaved the inside of the nose of the hook with a utility knife and then polished and shaped the cut with a fine file. Ultimately, I got a fit that is secure but not so tight as the original. I now consider it an upgrade.
Additional to the $3.30, I spent an additional fifteen minutes on this little project.
The funny thing is that I normally purchase German cars, synthetic oil, good tires and quality parts. While it's generally not cheap, I have always felt that the value is there. However, this little booger just made me feel badly used.
We now return you to our regularly scheduled programming.
#30
I just received a Chinese clip to replace one broken a couple of weeks ago. Haven't opened the package yet, but I'll look at it with your post in mind. $9 vs. $40 was just too good to pass up. If it doesn't work, no big loss and I'll order a OEM one.
