Last edit by: IB Advertising
- Audi Q5 How to Tow with Q5<br>Step by step instructions for do-it-yourself repairs.
Anyone towing with their Q5?
#13
I'm towing a 1300 pound camping trailer and it is fine. Drops gas mileage somewhat but not terrible. At 4400 rating I'd not want to tow more than 2200 which is half. From Seattle most directions involve mountains and I want plenty of wiggle room. This is a 2.0 and you don't even know the trailer is there. The big mirrors are great, too.
allgrrl in Seattle
allgrrl in Seattle
#14
The trailer had surge brakes which as always are a little clunky but very effective. So braking was no trouble at all though as always you need to drive accordingly. I was more concerned about the Camry breaking loose than anything else.
With the factory fit, dealer fit (if done properly) and DIY fit (again if done properly), the trailer control module is fitted which interfaces with the car's electronics including the ESP which has a specific function to control trailer sway. I have the trailer control module all rigged up and I didn't experience any untoward trailer sway.
the whole set up tows like a champ!
Thanks for the info. After searching the forum, it seems like the Audi hitch is a little less expensive to install when you have the S-line due to the "trap door" already on the S bumper cover, which is great because I'm looking at the S-line anyway.
I can't seem to find any definitive info on the the EBC. Does the OEM hitch come as a package with the EBC, or is it not actually a controller but instead an interface? Sounds like it is integrated with the ECU because some of the posts indicated that it affects engine and tranny settings. Is it simply a module that plugs into a harness in the back, and then you buy a brake controller separately?
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Hey, I'm in Oly and agree, lots of "hills" and mountains! I'll most likely be going with a 3.2, and am wondering if towing a 3000lb 18ft ski boat and trailer over to Chelan would be possible? Not on a regular basis, maybe once a year when we want to actually experience sunshine, mostly just shorter trips to lakes or the sound which I have no doubt it could handle. I'm thinking an OEM hitch and a trailer with surge brakes would most likely suffice with the weight I'll be towing.
#15
You are correct - if towing is a priority, a turbo is the better choice for high altitude towing and a turbo diesel is even better
https://www.audiworld.com/forums/alb...albumid=164922
#16
What exactly is required to tow with the Q5? Our Q5 has the factory tow package on the window sticker. From what I’ve read here, it appears that the Q5 has the hookup for lights, but not for electronic braking and the computer has the mapping for towing and the sway control. Is that correct? Would Audi service have the required accessories for brakes or would it be better to go to a trailer company for their professional assistance?
#17
12 year Audi owner
One warning if you go this route, there is a removable plate in the back-bottom of the vehicle. The dealer took this plate out for the hitch and electrical plug to come through and then left the plate out when done. Interestingly, the plate has an outline on its back side to cut out for a proper fit around the tow hook. I'm still trying to get the dealer to finish the job and do that cutout as to me it looks very unfinished just having the entire plate out. If this doesn't resolve soon I'll have to get the Dremel out and do the cutting myself.
#18
I tow somwhat regularily with my 2009 3.2. Installed the Audi hitch myself soon after I got the car. Very easy install.
I have towed a small 17' boat on several 300+ mile trips, a small utility trailer with misc stuff on board and a small Kubota tractor/front end loader 600 miles. Heaviest load has probably been 2000 lbs. No problems whatsoever with handling or acceleration. Gas mileage suffers a little but no more than wiht a stiff headwind.
I have used my Q5 to put a 26' 5000 lb boat in and out of the water with no problems but I only take it about 2 blocks, very slowly. Definitely looks like the tail wagging the dog. Pulls it right out even on a steep slippery ramp.
#19
I rented a 2.0TDi a couple years ago to tow a car up to england to get tuned. A total of 24 hours of towing with it during th trip with no problems.
![Name: P1090663.jpg
Size: 143.8 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/79316d1501279994-anyone-towing-their-q5-p1090663.jpg)
#20
<a href="http://s63.photobucket.com/albums/h122/CrustyNoodle/Audi/?action=view&current=IMG_1393.jpg" target="_blank"><img src="http://i63.photobucket.com/albums/h122/CrustyNoodle/Audi/IMG_1393.jpg" border="0" alt="Photobucket"></a>
Effortless...
Audi TDI POWER
Effortless...
Audi TDI POWER
