Artist/Song Info not updating on HD radio
Has anyone else experienced this, it is pretty annoying,. When listening to FM HD stations, the artist and song info that displays while the station is on does not update when the songs change. It stays the same until you change the station. When you go back, the correct info pops up.
It is actually so bad that when I program the stations into presets, instead of station names/letters I sometimes get the song that played at the time I programmed the station. It just stays there.
Any way to fix this? Does the software need to be updated?
Any ideas would be appreciated.
Thanks
Andrew
Thanks
Andrew
I cant say that I had the exact same issue. However, I was immediately unhappy with HD radio in my new Q5. The HD option would not show up right away for some stations. There were intermittent pauses (most annoying) and station info and artist were not always correct. I didn't see an advantage to HD so i turned it off.
As a note. I got a copy of the dealer checklist mixed in with my paperwork. Verify HD radio is turned OFF was one of the items to check...
AudiWorld Expert
A.
Sean M
11-20-1999 02:25 AM
