Audi Q5 Crossbar Noise & Solutions
Hey Guys,
I'm just wondering if any of you have tried either of the following to reduce noise with the crossbars:
Thule Wind Diffuser
- this can be seen at: http://www.thule.com/en-US/US/Produc...Load-Bar-Pair#
- it's basically a finned rubber insert fo the T-Slot... wondering if it works in the Q5 bar
Thule Fairing
- http://www.thule.com/en-US/US/Produc...airing-44-inch
- I'm wondering if this can attach to the crossbars that Audi provides
I've also seen a fairing made by Inno.
Thule Wind Diffuser
Thule Fairing
+1
Have you got the rubber strip that came with the bars fitted? This makes a big difference to the noise.
Also did you know that fitting the roof bars alters the ESP program by making it more sensitive to compensate for a potentially higher centre of gravity?
Thanks everyone for your replies. I suppose I should have been more clear with my first post. I have done a search and I know that removing the bars is the preferred solution for many of you. However, I do not want to remove them every time since I use them so often. I would prefer to find a solution that will let me keep them on all the time, while minimizing the noise as much as possible.
I do. I noticed that Thule uses a ribbed or finned rubber strip instead of a flat one to improve the airflow around the bar and was wondering if anyone has tried that.
I'm also surprised that no one has suggested using a fairing which would be the first solution to this problem. I do admit that it's not the prettiest solution.
au contraire mon frere... I love the look of the fairing, and I am actually trying to figure out how to fit one to my Volvo cross bars without too much jerry-rigging.
Others have posted that these are a good solution.
http://www.whispbar.eu/
http://www.roofbox.co.uk/scripts/rbv...ith+roof+rails
Eskayo - Did you find a solution?
I am looking for a fairing myself right now for my 2011 Q5. The Thule fairing DOES NOT fit the Audi crossbars (trust me, I tried).
Local rack store directed me to try a Inno fairing and I am going to check them out today. They only have small and large in stock so I hope one of them fits.
Headed to Mammoth this weekend and I cannot stand to hear that whistle for 7 hours straight...
I have nixed the idea of using a fairing. I am most likely going to suck it up and buy a different bar system that is aerodynamically quieter. It's an added expense, but it will let me leave the bars on all the time, and not worry about the look of a fairing.
