Last edit by: IB Advertising
- Audi Q5 Brake Pad Reviews<br>Review and comparison of top products.
Brake Dust from pads excessive
#21
I ran Hawk HPS on a Brembo 4-wheel BBK in a previous car (E39 M5) and they were very impressive performance-wise and low dusting as well. They were a tad noisy however and dustier than the dead-quiet, extremely low dusting Centrics I have on my RS4 and Q5.
BTW, a good source (Dave Zechenhausen) told me that one (both?) of the owner(s) of Centrics drives/drove a Centric Posi pad-equipped RS4.
#22
HZ60: I swapped out my pads before the stockers got too worn down so VAG-COM wasn't necessary.
tomashek: Dave Zechhausen at Zeckhausen Racing:
http://store.zeckhausen.com/catalog/...h=44_2617_2618
Thanks very much for the tip!
#23
Good thinking! If the pistons aren't extended too far you don't need to push them back. Never thought about that. I've only got about 9k mi , about 4k on the highway and plenty of pad left. Hate to pay someone to do something I've been doing for years just because of a computer. Damn new cars!! (The HZ60 should actually be 61 now)
#24
Would you suggest using brake cleaner or some other solvent or mechanically abrading with a wire wheel or a fine sanding disk? Are there any special tools needed or just the standard metric wrenches, allens, torx etc? Thanks for the heads up on the rotors!
#25
http://www.zeckhausen.com/bedding_in_brakes.htm
#26
Not to be cheated out of some good fun! A good bedding-in will take care of that...
http://www.essexparts.com/learning-c.../swapping_pads
#27
I use common sandpaper. 60 first then 100. Sand in a circular motion. Brakleen to spray away residue. The you're good to go. Make sure you have 18mm, IIRC.
#28
#29
Hi all,
So swapping pads will help for brake dust, but will it eliminate freakish squeaking brake sound when car comes to complete stop? I tried bedding, but it helps for couple days only and squeaking noise comes back. When I gently release brake pedal when at stop – it starts rolling slowly and it makes this horrendous squeaking sound.
So, is it a brake pads problem? Will swapping those help?
#30
Anybody else annoyed by excessive brake dust on your wheels. It just ticks me off that you can wash it and 2 days later dark brake dust is all over the wheels and lower front rocker panel. I have done research and thinking about replacing pads with EBC redstuff.
Questions
1- has anybody tried these or others
2- wonder if it would void warranty in any way (not going to dealer)
2011 Q5 3.2 quattro. 3,000 miles
It can just be mine because i see others going down the road and there wheels look like crap
Questions
