Brakes automatically applied with cruise control?
Here's one that I just learned: When descending a steep hill with cruise control on, the car is automatically turning on the brake lights. Does the car use the braking system to slow the vehicle? I've noticed the same thing when engaging cruise control that was previously set for a slower speed. The car REALLY slows quickly... not cool for trailing tailgaters. I'm not really sure if I like the car applying brakes without my permission. What do you folks think?
Yes, the brakes are applied and the brake lights do come on. I really dis-like that feature. I end up turning off the cruise control when I approach a long downhill section.
It seems like the cruise control system tries to maintain a +/- 2km window.
Also, if you have cruise engaged, try holding DOWN the cruise stalk . . . the car will brake aggressively. Use caution if you have someone behind.
in general i really like Audi's implementation on cruise control. Very precise and responsive. I see your point driving 75mph and resuming cruise control that was set to 35mph could be a unwanted surprise. But to somewhat counter that they have the last set cruise speed displayed on the screen for you. One more thing to learn and remember i guess
I did that on the parkway. I thought it would just coast down to speed and then I could let go to set a lower speed like all other speed controls that I had ever used.(This is my first Aud/Europeon vehicle) Boy was I surprised, when the Q felt like it was making an emergency stop. I will not be doing that again! My stone-headed Beagle made freinds with the back of the passengers seat. It is much safer and smoother to modulate the speed with the brake and then reset the cruise.
John, same here. I don't recall owning any other marque that would apply the brakes if the cruise control stalk was held down...it typically acted like the COAST function found on a GM car.
I'm pretty sure our recent Benzes would apply the brakes and downshift if you were on a steep hill, gaining speed, but not as intrusively as the Audis are doing it.
I actually like this feature; living in the Lake Tahoe area. We have very zealous CHP officer's who position themselves on the downhill segments, just waiting for speeders.
Our previous Benzie ML350 had this feature, but did not light up the brake-lights unless it was really applying force. The wife's Q5 seems to light up at any level of braking.
We've had an Escalade, Denali and now I have a Range Rover, and none has any downhill control. I wish it did.
I posted about this a year or so ago when I noticed the brake lights comng on while on cruise. Nobody then seemed to think that it happened. Good to see I'm not the only one that noticed this. I personally don't like it.
This is a good feature and I have learned that if you apply a little gas going down hills it overrides the system and will not break.
My first surprise was when passing someone and once I got back into my lane and left off the gas the car went into a hard break to get back to the set speed. I'm not one to p*ssyfoot'n around when passing. I give gas and get around then. So I'm usually up to 20 over during passing.
I figured out this whole braking thing last night. I can see the vehicle's brake lights reflected onto the backside of my trailer. This "feature" sucks!
![EEK!](https://www.audiworld.com/forums/images/smilies/eek.gif)
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
