Can you turn off rain sensor logic with CAR menu?
In manual it is said that in some regions one can disable rain sensor logic via CAR menu and just use control on top of right stalk to control pause between the wipes. Do you guys have this option in your CAR menu? Trying to figure out which VCDS setting controls it.
2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
G397_RLFS H06 0002
and has coding 02005C. VCDS knows nothing about coding this module. Since byte 0 is 02 as for pre-2013, I changed its bit 6 to 1 and tried - no luck. It is very likely that function of deciding whether to rely on rain sensor or use fixed pause has moved to different module (like the root 09 module - central electric). Just looked in teh manual and it says that it is possible to adjust this setting only via MMI, so definitely in 2013 something changed around this functionality.
Yes, I looked the manual more carefully and found that one needs to have MMI to be able to control this feature out of the box, so it is not so easy... But I'm not actually looking how to control it, I just want to disable rain sensor forever.
Thank you, this is the suggestion I came across a few days ago, unfortunately it does not work on 2013 models, that's why I'm asking... In 2013 module is called differently:
G397_RLFS H06 0002
G397_RLFS H06 0002
Yes, newest data in VCDS. Still seems to be missing quite a lot. I have posted here a solution to engine off when door is opened and driver's seatbelt is unlocked (module 46, last byte change from 0F to 00) - got it on motor-talk.de forum, VCDS still does not know about this byte. Wondering how motor-talk.de guys got this information.
TKS
luckymike13
A4 (B7 Platform) Discussion
05-16-2016 02:26 PM
Ringless
12v V6 Discussion
11-30-2005 03:49 AM
