Cannot put gas in
#11
Fuel systems are very tightly sealed, to limit evaporation of fuel. Not to "save" fuel but for emissions control. It is not uncommon for the hissing sound when you "break the seal". I'm not actually sure if it is relieving internal pressure or sucking in outside air. Either way, it's a sign the system is actually working right.
#12
Just to be clear, I've been pumping my own gas for 40 years - in this Q5 for 18 months. In all attempts to fill up but two it has worked as it should and it wasn't a different gas station where the problem happened. As previously mentioned, after 'powered cycling' the ignition the second time the problem went away. This isn't a pop the seal noise, it is like a fan running continuously. It is loud and you would know if it happened to you. Clearly it's not a common problem with the Q5. It's still under warranty so I'll mention it the next time I have it in for service.
#13
If as another poster stated, the carbon canister is blocked it also won't allow the proper venting of the fuel tank. The carbon canister is vented through the Pressurization Pump when it is in vent mode.
There is also a small button inside the fueling hole that opens this venting system. The refueling nozzle must go in properly to push the button.
Thus any of the three times above can cause a none venting tank and difficulty in refueling.
I've been there with this problem, my dealer and Audi engineering said it definitely was a bad fuel tank that needed to be replaced, which required half the car/chassis taken apart and we all know that it would never be put back together correctly again. I did my homework and own testing and proved to them that it was indeed the carbon canister, it was! They gave me a new Evap Carbon Canister and a free fill up for me efforts, and sent the new ordered gas tank back to Germany!!
#14
Do you fill up with the car turned off?
#15
AudiWorld Expert
#16
Most Audi vehicles have an Evaporation Pressurization pump. that pressurizes the Evap system at startup and performs a leakdown check. If it detects a leak it throws a code. This Pressuratization pump after a few minutes, turns into the fuel tank vent.
Digging up an old thread, but this (unable to add fuel to the tank without the pump stopping almost immediately) has recently begun happening to me...can anyone tell me where the Q5's evap canister is located? Thx!
#17
You didn't state what year Q5, the following if for MY 2013+
Pull of the #6 tank to evap canister vent hose off the canister. See if you can fill up the tank. Report back here...……….
![](https://cimg3.ibsrv.net/gimg/www.audiworld.com-vbulletin/1057x669/evap1_3dd00d012b69efe520f6bef052f969a0336fd5a1.jpg)
![](https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/1074x850/evap2_7a69afc8b1e9caca2265b8d8aa883d9b857d28cc.jpg)
#20
Yes, since 1996 when AudiWorld was first called Jet's A4 Pages, then A4.org, on to AW...……
You know what is sad, is that for the last 23 years I looked at these forums almost every hour that I was awake while working, traveling the world, now in retirement as long as there was a computer connected to the WEB around. Now it's mostly all cell phone.
