car shakes when shifting gears
hi guys,
I have a 2011 Q5 3.2L.
I am seeing this problem everyday. when my Q5 starts to run, it always shakes when shifting from D2->D3 and D3->D4. you can feel a little bang. I see this issue since the first day I got this car.
So i'm wondering if this is a common issue among Q5?
I really appreciate your responses!
I am curious if this happens at all load (throttle) settings? I find if just casually accelerating, it is very smooth and I don't feel anything. If in sport mode and under heavy acceleration, I can feel a little bang into the next gear, but not in a bad way, a good way.
hi guys,
I get a small push when running it in manual mode at lower speeds.. smooth as silk in auto mode, don't how carbon buildup could cause this since my car just went through it.
does it shake at idle too? how many miles were on it when you purchased?
hi guys,
the 'bang' is very obvious when d3->d4. d2->d3 has it as well but less noticable.
Both my 2011 and my 2012 Q5 had this issue. Most of the loaner cars we had during our ownership experience that had a 6 speed transmission, also had this issue. They also exhibited this trait when downshifting through those gears, but to a lesser extent. It feels like a jerk, sometimes small, most of the time large, as it switches gears, if yours is the same as mine was. It was always the 2nd-3rd, and sometimes 3rd-4th gear shifts, all others were smooth as anything. There is no fix for it that we could ever find. If you take it to the dealership and ask them to fix it, they'll tell you they're going to "re-adapt" the transmission. If they do it, make sure they re-adapt ALL gear shifts, because just doing one or two makes a bad problem significantly worse. I know this from experience.
besides this issue, occasionally the wheel also creates some ga-ga noise when i turn it sharp under slow speed or stationary. because this doesn't happen always so dealer doesn't think there is a problem.
i really like Audi's appearence. but i most likely will avoid it next time when i update my car.
shahineo
A4 (B8 Platform) Discussion
31
04-15-2011 07:25 AM
kevrandall
07-07-2006 04:27 AM
Gus
12
06-20-2005 07:39 PM
