Changing the D3S bulb
Has anyone sucessfully changed their D3S bulbs yet? I know a member tried to change the bulbs and had problem with leveling.
Do you mind explain how you get done or share your experience in the following thread http://www.audiforum.ca/q5-q7/51746-...ght-led-6.html
Thanks,
Soni
Thanks,
Soni
I have taken out the passenger side bulb, and try to fit in the new bulb that I bought, somehow it wouldn't sit in properly. I look at the oem and the bulb that I bought, sizes are exactly the same. Then I try the fit back the oem bulb, same thing, wouldn't sit properly and now the light is always on high beam level. And trick of installing this light with all these craws looking thingy?
Did you use vag-com to lock leveling to service level?
I tried to adjust my lights higher and without locking the leveling it didn't make difference. Once I used vag-com to lock it, I was able to see the difference while turning the adjusting screw.
Thanks!
A8L Man
02-24-2011 11:20 AM
raketeS4~AlmostFixed
09-05-2007 09:37 AM
Clues
05-07-2003 11:07 AM
