DIY - Execuhitch Hitch install on 2013 Audi Q5
#11
The S-Line rear bumpers have the removable panel. I 'believe' the standard bumper (non s-line) does not, so you would have to cut the piece out for the hitch to be exposed. That is the way it works for the standard hitch anyway. I think if you search the forum there is a couple of folks that installed the OEM hitch on non s-line's.
Thanks,
tgt
Thanks,
tgt
#12
-There is a plastic lip/bracket that is fastened at the bottom of the wheel well on each side. Again, these need to be released. If you do not, as you pull the rear bumper off with any force (thinking it should be free) you may snap these plastic brackets which will be an issue when you try and re-install the bumper.
Thnaks again!
#13
-tgt
#15
Thanks again!
Standard bolts: 30 ft-lbs (40 Nm)
![](https://cimg5.ibsrv.net/gimg/www.audiworld.com-vbulletin/507x541/impactbar_dfac96bb056ac5b1d2f78607efe37ac7dd2ee900.jpg)
High grade bolts: 44 ft-lbs (60 Nm)
![](https://cimg6.ibsrv.net/gimg/www.audiworld.com-vbulletin/681x695/towingbracket_422203ad4007e1447eaf7e972069fd607d0814c2.jpg)
#16
Torque spec quoted was the revised specs from the Execuhitch folks. I assume they checked prior to updating, but that is an assumption on my part. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
-tgt
-tgt
#17
The Audi hitch comes with 10.9 class bolt (part number N10012402) with a maximum dry torque of 53 ft-lbs. Audi specification for those is 44 ft-lbs.
#18
-The 2 ‘extra’ included bolts (that are used to mount the hitch), are installed toward the front of the vehicle inline with the existing bolts. There is tape over the holes in the Q5 body. When removed, the bolts are installed in that location (one on each side, toward the front of the Q5).
#19
