Do the rear wheels have negative camber
Yes. The factory specs on my 2010 Q5 for the rear are; Camber 1 degree and 20 minutes and the front 25 minutes.
What surprised my about the Q5 is there are no provisions to set the caster or camber in the front! You get what you get unless you want to install aftermarket suspension parts.
Hope this helps.
Hope this helps.
Thank you for your reply. Does this translate to -1.33 deg(rear) and -.42 deg(front)? I really don't like negative camber as it will cause uneven and pre-mature wear on tires as they do on my 530i so much.
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
firemandan
09-15-2015 08:02 AM
PoisonBeef
09-04-2015 05:29 AM
Al_Bundy
09-02-2015 07:24 AM
