When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hello,
I just noticed this evening that the after starting car the tiny yellowish halogen light in between the xenon bulb and turn signal within the front casing was lit? But only on one side
Are these the high beams and why was only one lit up?
Thx
JR
Can you take a picture of the light you are talking about? I believe the high beams are activated by adjusting the internal focus of the HID headlight. There is not a separate light for the high beams.
AFAIK the fog light does *not* normally come on with any cornering light, on the US models, but that is an option that can be changed in the car's computer, if someone has been poking around there. (And the fog light may stay on long enough so that you start to wonder, why is one fog light burned out...the cornering having been done "so" long ago.)
I just turned on the car this evening and along with the night lights was on only one of the middle yellowish light passenger side !?! Is the driver side burnt . Then i turn off car and they are both off
Any ideas?
