First Rattle
Old 07-26-2011, 04:09 PM
  #11
QQQQuattro's Avatar
I have an annoying rattle that seems to be coming from inside the pillar beside my ear (behind the seat belt adjuster). How easy or difficult would it be to pop the trim off on the pillar, has anyone ever done so? I don't want to damage anything, so any help is appreciated!
Old 07-26-2011, 06:59 PM
  #12
HaveBullDogWillTravel's Avatar
I experienced what I thought was a rattle in this area but it turned out to be more of a creak. I eventually attributed the noise to friction between the glass and the weatherstripping on the driver's door. Next time you hear your noise try lowering the window just a bit and see if it stops. If it does stop then all you need to do is apply some spray silicone lube to the rubber weatherstriping in the channel the glass fits into. Spray a Q-tip and drag through the channel.
Old 07-27-2011, 08:46 AM
  #13
QQQQuattro's Avatar
Will give that a shot...thanks!
Old 07-27-2011, 09:17 AM
  #14
eppoh7's Avatar
I have this creak too. Just started happening. At first i thought the window relay was bad and the motor was not disengaging. I'll try the silicone and see if that makes it go away.
Chris
S4 (B8 Platform) Discussion
26
01-22-2010 05:45 AM
AudimanVA
05-09-2005 09:19 PM
BruceMc
RS 6 Discussion (C5)
12-11-2004 08:03 AM
Ming 2.7T
07-10-2002 01:17 PM
Quick Reply: First Rattle
