Got some V1 goodies to install...
#12
Mine does. It's sold by V1. All is from V1 except the mute button.
http://www.valentine1.com/v1info/bob.asp
#14
My V1 has effectively become an 'Audi detector' on the freeway with all the SOB's who bought side assist lighting it up like a state trooper... booo!
Don't order/pull the fuse on side assist, and use your mirrors like a real driver.
#15
Or a Mercedes Distronic detector. Try disabling POP and encouraging Valentine to work on a better bit of signal analysis.
Seriously - low power 24 GHz isn't regulated, so it only gonna get worse....
#16
#17
#19
Mark,
Have you settled on a location for the remote display yet? Do you plan to modify the remote display for fit like you did in he S4 or install as provided?
Also, how will you connect the mute button? Do you plan to use the 3-way direct-wire splitter sold by the same eBay seller? If so, how will that work with the Savvy? Is it possible to just use a regular telephone line splitter to make two accessory ports for the remote display and the mute button?
#20
Answering my own splitter question:
Yes, a standard 4-wire telephone line splitter can be used to connect multiple accessories to the Acc Port on the Savvy. The V1 website identifies some 2-port options, but I have read successful reports of using 3-port splitters (e.g., for V1connection, concealed display, and mute button).
http://www.valentine1.com/V1info/techheadquarters/
PGAudi
01-27-2001 04:32 PM
DoubleClutch
09-07-2000 09:34 PM
Marcus Frost
05-21-1999 07:11 AM
