Hartmann Wheels
#21
Thank you Elevens and by-tor for the information. It sounds like the Hartmann rims wouldn't be a bad substitute for the Audi S-Line rims. You've both made the decision to purchase them much easier.
#22
Can someone elaborate on the no TPMS sensor requirement with 2010+? How does the TPMS work then?
#23
Audi uses a relatively new idea for TPMS implementation. Since the Audi has traction control, and there is a wheel spin sensor at all four corners, Audi employs a "software" solution to detect a wheel which has lost significant pressure.
The rolling RPM of every wheel is averaged while in motion, and if a wheel begins loosing pressure, this average will change for the afflicted wheel due to deformation. Granted, the amount of pressure loss is going to be more significant (compared to sensor methods) before the TPMS warns you, but apparently this passes government guidelines.
#24
#25
Just wondering if you have any more pics of this set up? and which offset did you went with?
I've just started looking for replica wheels, and find the width/offset of Hartmann wheels a little more aggressive than I would like.
Another option is the TT RS replicas being sold by PYSpeed, they have the closest offset to stock wheels, but unsure about the quality...
http://www.pyspeed.com/AU510-OEM-Rep...m-au510-19.htm
#26
http://shop.achtuning.com/Hartmann-H...eels-Audi.aspx
#27
I believe the 20" s line wheels have a 33mm offset. I see several offsets offered on after market wheels. What should I be thinking about when choosing the offset?
Also are wheels sold by oemwheels.com abd oewheelsllc.com not as good as Hartmann? The first 2 are much cheaper.
#28
The S-Line 20" wheel has a 33mm offset, with a 8.5" width. The cheapo's on eBay have 35 or 40mm offsets, with a 9" width. This will not work without a wheel spacer, which they put in the fine print.
Hartmann's 20" wheels for Q5 have a 25mm offset with their 20x9 wheels. This correctly compensates for the additional width of the wheel. This movement outward will not overshoot the fender either, as the Q5 has some room there.
Hartmann has some pics of the Q5 with the larger wheels so you can verify the clearance.
#29
I contacted Achtuning yesterday, the Titanium edition wheels should be available in late May. Thinking I might pick up a set.
http://www.audisouth.co.uk/Audi_Sout...CK-EDITION.gif
#30
Great info! I wanted to confirm that my Q5 19 in. 5 spoke wheels with tire size 235/55 will fit on the Hartmann 19 in. triple 5 spoke wheel? I saw somwhere that tire size should be 255.
If you look at the top control arm of your Q5, you will see there is NO room for error. You need to drop the wheel offset as you go with larger width wheels. Also, you cannot use a much larger diameter tire without hitting the top journal.
