Heated side mirrors
Last night, my wife turned on the heated side mirror and it did not work. It was a warm summer night after some rain so the side mirror was foggy, the temp was about 75 deg. The mirror **** was in the center position. I know that the Audi heated mirrors have a temp sensor in it which prevents the heat element from coming on at a certain temp, does anybody else have problem defogging the side mirror when its 70 deg outside? There are some post that suggusted having the mirror adjustment **** in the middle and pushing it once will override the temp sensors, anybody know if there is any truth to that?
I do not have the user manual at hand, maybe you should take a look at it.
If it works as I think, I must say it is not the most intuitive thing... At least there are not too many thigns like that in the Q5.
If I am not mistaken, I believe that the defrost for the mirrors is linked with the one for the rear window. If the **** is at the defrost position and you turn on the rear defrost, it will work.
i think i remember the dealer telling me that the heat needs to be on in order for the mirrors to defrost with the **** in the center position. I could be wrong on this one but give that a try.
the heat does not have to be on in order for the heated mirrors to work. my guess is that it was too hot outside for the heater mirrors to work effectively in this case.
You are right, we try it the other day when it was 60 deg out and it worked. So if you have a foggy side mirror after a rain storm on a hot summer day, you are out of luck. They should have just have it run on a timer like everyone else.
F3A
22
08-02-2003 09:45 PM
Xymox007
01-06-2003 11:46 AM
