HomeLink for my condo?
#11
#12
I think the HomeLink transmitter might be a little weak, too. I have to drive up pretty close to the garage door to get it to react, while the stock remote works from the street at almost three times the distance.
#15
what brand is your condo gate opener? if it is DKS doorking - you should be able to program it using the MMI instructions under "garage door opener".
I had tried this in the past and was not able to do it and read somewhere that putting in a new battery in the clicker before programming the car might do the trick. So i inserted a new 23A, 12V battery in the dks clicker and followed the instructions in the mmi - once the homelink button is successfully programmed, the hazards blink twice and you are all set. It took me all of two minutes to do this. I think the key is a "new battery in the clicker". Hope it helps.
fleebailey33
Audi A3 / S3 / RS 3 MKII
08-30-2015 07:38 PM
ChrisS -2008 A6-4.2
05-17-2000 03:01 PM
