I found that the ABS-sensor based TPMS works
#11
Mark, lengthy document here on compliance testing of the new system:
http://www.tpmsmaderight.com/pdf/TRTR-640937-2009.pdf
#12
Glad it worked out for you Mark, but the wheel sensors can tell you which is low, it's just the specific implementation on any prior vehicle might not relay that information. My Odyssey will tell me which is low, as well as (if I go to the screen) what the pressures are at each corner. Still, it'll be nice to not have to worry about the sensors going bad or anything since I can check exact pressures myself and all I really need is the notice that something's wrong.
uberwgn (12-12-2020)
#13
Not sure about the Q5 but in the C7s, the indirect system will alert and point you to the specific offending tire. Not as slick as the A8 readouts but at least there's no guessing which tire is low as was the case on my '09 A4 which just alerted that one of the four tires was down (it had direct sensors).
#14
AudiWorld Expert
Wow, that's insane. My Odyssey is a 2009 and Honda's system points out the exact tire (and as mentioned also can show you pressure per tire). Pretty crazy that you wouldn't at least get a notification on which tire is low, even if they didn't give you the actual PSI readings with the wheel sensors on the A4.
Btw it may br useful to avoid the term "wheel sensor" as both the indirect "abs sensor" and the direct "pressure sensor" could be considered under that term and may confuse some.
#15
And again I'll note that I don't think it's insane. Indirect system is clearly tied to the specific wheel (abs sensors have known locations), while direct systems use wireless interface and can mive around (pressure sensor is in tire). So I'd say it'd be "insane" if the indirect system didn't tell you the specific tire, but not do if a direct system didn't tell you which one.
#16
AudiWorld Expert
At least all cars now require some form of TPMS saving tires and lives
#17
Don't give Honda too much credit. My 2008 MDX could display individual tire pressures, and it would automatically recognize new sensors when switching over to the winter wheels. My 2012 Odyssey Touring cannot display individual tire pressures (yes, Honda de-contented), and I need to program the sensors' ESNs into the car which necsessitated the purchase of the $150 tool.
d0nut s4
02-11-2016 04:48 AM
CPLYONS
09-07-2015 07:19 PM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
