Iphone directory won't load
I have a new q5 and a new iphone 4s (ios5). The bluetooth connects with the car and calling and even siri seem to work (it thinks it is connected in a call to my number for siri).
However, the directory from my phone isn't loading. The dealer says it should happen automatically. I don't see a way to do it manually.
Any advice.
PS. See my other posts on my opinion of Siri
Any advice.
Any advice.
Any advice.
Thanks for the advice. I have syn on. I will try the hard reboot. As far as less than 100 contacts, who has that. I have hundreds...
I am wondering if anyone else has a iphone 4 or 4s with ios5. Is it working for you?
I have iPhone 4 and iOS 5. It works fine for me. Again, make sure that Bluetooth settings are correct on both the phone and the Q5.
Prob will go to a Galaxy anyway....
Not too many settings to go wrong on the audi that I can see. It should import automatically. I definitely have it set to sync on the iphone. Shouldn't be the hardware so there shouldn't be a diff between 4 and 4s. Thanks for confirming that it does work with ios5. Now I just have to figure out what is wrong with my setup.
It seems to load my icloud and gmail contacts. Everything is duplicated. I can live with that.
Also, the voice recognition (now that I can use it to search the directory) cannot seem to get the word "fox" (a last name) no matter how I pronounce it. I am going to do the training. I hope that works.
Went through and fixed contact entries that had text in number fields and other wrong entries. I only went through C in my directory with several hundred untouched... but it was enough. They all now load.
AudiWorld Expert
@Radman - can you be more specific in what you mean by correcting items with "text in the number fields"? My iPhone 4 used to work just fine with my Audi Q5...and then in August it just stopped. The actual pairing will work, and I can make calls...however, none of my contacts will enter, so I can't use handsfree dialing. I've gone to the apple store and had my phone restored to original settings. Other than getting a new phone (which I will try) what worked for you?
I also think where the contact list is stored is a issue. whether it is on the phone, sd card etc.
That said I could not get my Samsung Captivate to work right but my new Skyrocket is perfect
radman2020
Q5/SQ5 MKI (8R) Discussion
20
11-12-2015 09:48 AM
gmoney
A4 (B7 Platform) Discussion
10
01-21-2007 11:39 AM
CrazyINP-12V Ivan
11-02-2005 09:07 PM
