MMI & Blackberry - HELP
I have a 2010 Q5. I have been using a new Blackberry Tour (Verizon) and, for the past 4 weeks, it paired beautifully and worked great with the MMI. Suddenly, now when the Bluetooth is connected with the MMI it will cancel whatever audio is playing (as if a call were being placed) and the MMI thinks that the phone is in use. This is without dialing out or any other action except for the automatic connection to the MMI via Bluetooth. I have tried rebooting the BB. I have brought the car into Audi and they say that there is no known issue with the BB and MMI and that my MMI software is up to date. They simply said "its your phone, not our car". With this issue, I cannot use the phone and the audio.
Has anyone had any issue with Blackberry and MMI? I am at a total loss here.
Many thanks
Many thanks
Many thanks
Many thanks
Have you able to connect your phone to other BT devices (bluetooth headset)?
I am grateful for your suggestions.
Kindly,
D
oh well. I found that suggestion on a blackberry board where another guy was having the same issue with a toyota. So it definitely looks like a blackberry issue and not an audi issue.
David,
try seat calm and remember - is there any chance you play with your BB a make some setting change or update new firmware or anything that can contribute to this issue.
Try to copy and paste here all your settings. Maybe we have some phone technision on this board who can help you. Also google to other cars (not auidi) forums - maybe you got lucky find your answer there.
Good luck.
But David state, that for few weeks everything work fine. The are no way Audi can upgrade their software over internet, but his phone provider can do some maintenance on the network , that make this happen.
David,
Good luck.
David,
Good luck.
Here is another discussion I found with the same problem (no solution):
http://priuschat.com/forums/gen-iii-...e-dialing.html
I use a blackberry storm, but luckily have not had any problems yet. It really does seem like this issue happens regardless of the car or network. So it's gotta be the BB software.
