Last edit by: IB Advertising
- Audi How to Recondition MMI Display<br>Step by step instructions for do-it-yourself repairs.
MMI Display Refurbish
#21
Here's the final result after installing the Targus screen protector. It's not terribly matte. In fact, it is less matte than the actual surface of the display. The colors are definitely more vivid than I remember them being. The original blue coating affected the colors far more than the new screen protector. I'll reserve my final judgement until I log some miles during the day.
#22
Like golfnguitarz asked.....
What is the best way to clean a STOCK screen? And specific products to find, and products to avoid? I really dont want to screw my good screen up.
Thanks
Chris
Thanks
Chris
#24
For what it's worth, page 241 of my manual states the following...
- Clean the display with a soft clean cloth and an LCD cleaner.
The display can be cleaned with a professionally available "LCD cleaner". The cloth should be slightly dampened with the cleaning fluid to clean the display.
! To avoid scratching the display, you should never clean it dry.
I'm not sure I buy that either. That blue AF coating is not a typical LCD feature. I think you're at risk with any type of cleaning agent. I also believe age plays a factor. The exposed blue coating was much easier to remove than the unexposed parts behind the main plastic bezel.
#25
OK...here is what I did.
When and if you go to one of those eyeglasses places they sell a pump spray bottle cleaner just for the delicate "plastic" type lenses. I'm talking about the BEST stuff they have. It works great, just use cotton ***** and press lightly. I just did my display and it looks great, and my glasses look great too.
Hope that helps
Chris
Hope that helps
Chris
#26
I'm quite pleased with the daytime results after installing the Targus, so I snapped the plastic bezel back in and took some final pictures. The display brightness was set right in the middle of the dial in all pictures.
Do I wish I had my original unblemished screen back? Yes.
Will a trained eye notice that this Q5's MMI is unlike all others? Probably not.
Have I achieved an equivalent level of anti-refection? Possibly not, but it's good enough.
Is this solution more vibrant and colorful? Yes!
Is this screen protector more durable than the original screen? Absolutely!
Am I happy that I didn't have to spend $1300 on a brand new display? YES!
One final tip for removing the bezel... It pulls directly outward. What you want to do is hook it from behind and pull straight out. Be careful to hook the backside of the bezel itself. It is quite easy to hook the little chrome ring instead. If you feel the chrome ring starting to give stop and push your tool in deeper and hook the backside of the bezel itself.
Many thanks to everyone who supported me on this fix!
Regards,
Scott
Regards,
Scott
#27
Good job Scott!
It looks great!
Thanks for the pictures. I didn't took the time to take some while I repaired mine. Now it is well documented.
Martin
It looks great!
Martin
Regards,
Scott
Regards,
Scott
#28
Having applied these things to mt iPad on occasion, very important to get the surface 100% dust free which is easier said than done. As you wipe, dust settles in another spot... Make sure the cloth you wipe with is completely lint free.
What does work very well for eliminating dust is some kits that include an adhesive paper sheet. You press this down on the clean screen and peel it off to remove all traces of fluff and stuff. Gotta get the protective film down quickly after that as dust will always be in the air.
#29
To bring this back to life
From what I read; use "1Z Cockpit Premium" to clean yours creens, new ones or your old ones.
It is easy to find on the Internet.
Probably covered but just in case.
I hope this helps.
Chris
I hope this helps.
Chris
#30
Looking for opinion on my problem. When I picked up my new Q5 from the dealer last month I discovered a scratch on the MMI screen when I got home. I took a pic and they said they will replace as it is under warranty of course. The problem is they have never replaced one of these before so I am worried that they will mess up my dash taking it out. Is that something anyone has experience with and do you think I should find another dealer so my MMI replacement does not get botched.
