MMI and fan speed on AC.
Just have a couple of questions for you guys.
1) Can you look up a certain store/restaurant on the Navi? For example I want to go to Ralphs supermarket, is there a function for this.
2) On the climate control, I am unable to set the fan speeds for the driver and passenger to different speeds, can this be done?
thanks!
thanks!
Yes to both.
1) without being in the car, I can't tell you specific on how to do this. But it is located under "enter point of interest" or something like that.
2) Just change the fan speed for each, using the fan speed button. There is one for each side.
2) This is only possible if you have the 3-zone AC.
In Europe is is possible to order the Q5 with 1-zone AC, don't know if this is possible in the US.
Please note that the 3-zone AC can be set in an master-slave configuration. If you press the climate control wheel on one side of the car for 3-4 seconds it becomes the master. (you will see that the temperatur of the master side is copied to the slave side of the car). A change in e.g. fan speed on the master side of the car will now be affect both sides of the car.
If you change settings on the slave side of the car the AC system will go back to individual settings.
My US spec master-slave works for vents and temp but fan runs same speed all the time no matter does driver or passenger set it...
Even dealer says fan speed stays same?
A4 Freak
08-07-2001 12:39 PM
Via911
14
04-09-2001 06:36 PM
