MY 2014 Navigation Maps version?
#12
Hopefully this issue is alleviated with the Audi Connect and being connected to Google... In Miami we are under construction of the major highways there are new exits and new traffic patterns. Google maps on my phone has been updated with the latest changes..
Will these new updates show with the Google overlay of Maps?
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
#13
With the Audi Connect Google "Online Destinations", the nav will show and direct you to a POI location on a new street not yet on the NavTeq map but it will not be able to ID the street in the routing. I seem to recall as you navigate onto a destination street not in the NavTeq database, it will just treat it as an "off road" routing and destination at that point, much like when you are navigating into a destination located in a large shopping center parking lot. Again, any new roads not in the internal database will be ignored for routing.
Google Online Destinations have essentially the same POIs as Google Maps and are updated dynamically online. The only way, though, to update the car's underlying NavTeq maps with new streets and addresses (and the internal POIs) is via a DVD sold by Audi dealers. They usually will require they install it which, apparently, takes a few hours to perform so it's not inexpensive. Not sure how often the map DVDs are updated.
Unless they add a bunch of new interstates in my area, I'll manage with Google Online Destinations POIs for a few years before I spend the big bucks for a map update since 99.9% of the time I'm not searching for a specific address on a new street and I use the Online Destination POIs pretty exclusively (The internal nav POIs are much more limited). Besides, the NavTeq map updates are typically a year or two out of date when released in any case.
#14
So keeping things current one will incur two charges. One to keep the T Mobile/Audi Connect service and then the charge for map updates. No wonder people opt just to use their phones. Lexus is the same with their subscription based eDestination and the need to update maps (usually $200-$300 for the update). I'm sure other brands are similar.
#15
the gen 2 MMI (D3 A8, C6 A6, many years of Q7, etc.) it was simple. Each model year, a new DVD was released. The version number was the model year. Thus, a v8 disk (like my A8 currently has due to a warranty related tweak), was issued for model year 2008. It originally came with a v6 disk, and of course is a 2006 vehicle.
Said another way, the traditional practice was to update them annually, and with the model year, not the calendar year. The data supplier was Navteq, same as now and with the Q5. I understand Audi has taken back over DVD distribution; Navteq had it for some years.
It was always "black box" as to what the exact updates were. and Navtek and Audi would typically only publish vague references like "updated POI's" or "expanded coverage in _____ areas." The D3's board sentiment was (and is) not much changed one year to the next, that maybe once in a while a new freeway onramp layout or some such would get tweaked, but nothing dramatic. Most just let it go and maybe some sprang for an update every 3 or 4 years, while others bought the used (hopefully genuine) DVD's from eBay that were somewhat older, but still newer than what they had installed.
I understand the Q5 system is now flash based, the dealer has to do it, and it's pricier; Audi's DVD's were somewhat less than Toyota's for example (which I also updated at one point).
For OP, a decent guess from the gen 2 MMI experience and known Audi approach there is a 2014 has the same (and new) 2014 update as any other MY 2014 will, but it will be almost impossible to get any real info on exactly what those updates really are.
#16
Pricier than the old DVD gen 2 MMI approach, and more attempts to sell it as an ongoing "service" with periodic "revenue streams." Don't like it, but I expect that's what their business model is now.
#17
Technology is supposed to make life better and while, arguably, it can, it don't come cheap.
#18
We'll use the Q5 for road trips, vacations etc. so the convenience is worth the cost for us. It's nice to be able to send destinations and POI's from Google Maps to the car when planning a trip or in route and have everything right there in the MMI.
#19
#20
In this case, though, Audi almost never updates maps for some unknown reason. You'll get whatever version they're putting on in the factory, and have to assume you'll never see anything newer. (As a corollary, you have to assume the maps being put on won't be very recent).
Hopefully they've got a better system in the works since never updating when everyone else has yearly updates from the same source provider is insane.
