My Q5 Magnaflow custom exhaust
#12
teasing of course, looks like a first rate install !
how did you decide on which to remove / replace ?
Did you do it in stages until you found the tone you wanted ?
as you know I replaced the two rear silencers....
and it is better, as heard in my signature tag,
but if taking out one more silencer would do even better
#19
With Turbo engines, You get the most HP increase with large least restrictive exhaust system (doesn't apply to normally aspirated engines). So I went with a straight through muffler like the Magnaflow.
The 2.0t Q5 has four mufflers, and since I'm installing a middle muffler, I decided to remove the Primary with an assumption that three mufflers were going to be silent enough. I did it all in on shot.
I looked through the primary muffler and it's not a straight through design. So there's a little bit of restriction there if I left it.
I'm estimating an increase of 13hp/13trq. Similar to the awe-tuning exhaust system.
#20
Techm8n...were you ever able to get any kind of video or sound clip? If all else fails just start the car, go to the back and call me...I'm about to jump the gun on the same setup
