New adapter cable for Apple Lightning port
Old 02-13-2015, 03:13 AM
  #81
spijun's Avatar
Originally Posted by samy999
P.s. I figured out how to check Software Version (By clicking Setup MMI)
Now only problem is it just shows a question mark and nothing else.
Here's a few pictures of my MMI:
This is Audi Navigation RMC Version , Europa
Someone did not do correctly firmware upgrade
Old 02-13-2015, 01:18 PM
  #82
samy999's Avatar
Thanks is there anyway to restore the firmware or update the firmware myself? As my local audi mk dealers were just rude and weren't interested, they were just trying to fob me off -.-
Old 05-04-2015, 09:01 AM
  #83
A6forMoi's Avatar
Excuse the newbie question on this . . .
Where does the adapter cable plug in? And, it looks short - where does it reach so you can plug in your iphone or other device to the lightning port end?
Old 05-04-2015, 11:11 AM
  #84
snagitseven's Avatar
I believe in the Q5 it's located in the glove box. In some other models it's located in the center console.
Old 07-15-2015, 04:44 AM
  #85
116Crew's Avatar
Quick question! Will this cable work for video on my 2015 A3 MMI Navigation? If so, will have to re-size the video pixel from 1080p to the right size? Thanks!
Old 07-15-2015, 08:04 AM
  #86
Doesn't the new 2015+ A3 use USB ports? If so, all you need is the appropriate USB to phone cable - no AMI cable necessary. As to MMI resolution for video, you need to check your MMI infotainment manual for the file format requirements. Audi changes the specs as new models are released.
Old 07-15-2015, 10:54 AM
  #87
116Crew's Avatar
No ;( The USB is for charging only.
Old 07-15-2015, 11:16 AM
  #88
So what type of port do you use to play music by wire from your phone? (Not bluetooth audio) Is it the Audi dedicated AMI port?
(You said you have an A3 even though we are in the Q5 forum).
Old 09-02-2015, 03:04 PM
  #89
mrjlevy
mrjlevy@hotmail.com's Avatar
Not through the AMI cable, only via Bluetooth Audio streaming. You can't have Bluetooth Audio activated in the MMI and the AMI cable connected at the same time on the same device - the MMI will be confused which to use. Try unplugging the iPhone from the AMI and ensuring the Bluetooth Audio is selected in the Tel>Settings>Bluetooth menu. The phone, of course, must be paired with the car's Bluetooth. It should then work.
A workaround to avoid plugging and unplugging and changing Bluetooth Audio settings that I use is my iPhone is paired for tel and Bluetooth Audio and an older iPod in the console for the AMI source. Then I can select either source in the MMI.
So am I hearing right that you cannot stream pandora, spotify etc using the AMI cable?
Old 09-02-2015, 03:13 PM
  #90
Correct. Only native iPhone/iPad audio and video files through the AMI (which can also be played using Bluetooth Audio).
visuar
TT (Mk3) Discussion
10
11-14-2017 01:56 PM
Chigger
S4 (B8 Platform) Discussion
11
10-07-2015 02:03 PM
iamdrewseph
10-01-2015 11:33 AM
mxp
09-28-2015 01:04 PM
Quick Reply: New adapter cable for Apple Lightning port
