New Shift Knob for 2.0T P+
New Shift **** for 2.0T P+
Looking for some ideas on a new shift **** for my 2011 2.0T P+.
I like the air leather peforated look, has anyone modded this successfully? I did a quick search on this forum and there were no concrete results.
I am aware of the Europrice shift **** but wanted to poll you guys for some options.
1 Post
https://www.audiworld.com/forums/sho....php?t=2828723
I installed the S-Tronic shifter on mine.
You have to heat and twist the plastic, and file it down to make sure it engages the plastic at the correct spot.
If you don't have a tool to reset the gear shifter, you'll probably need one. My dad and I did the project together and made a tool out of a drill bit end.
Good luck!
Good luck!
http://www.ebay.de/itm/NEU-Audi-V8-4...item589419e6d7
no need to change anything... still you have to know how to install this selector lever... it is 10 min process...
Removing old selector lever
– Prise out gear lever boot using removal wedge and pull upwards to detach.
– Pull boot up and over gear ****.
– Open clip and pull off gear **** together with boot.
Installing new (Q5 2013) selector lever handle
When installing the selector lever handle, the interlock button must be pulled out to the stop and secured with either a cable tie or with the assembly aid supplied together with the new handle.
– Shift selector lever into position „N“.
Note: The selector lever can be moved by pulling the release rod.
– Turn selector lever boot inside out over selector lever handle.
– Turn locking ring as far as stop in direction so that markings -v- and -^- are no longer in line.
– With interlock button facing driver's side, push selector lever handle fully onto selector lever so that catch engages.
Not so clear without pictures, sorry...
