Permanently Disable "Service Due" Light
so that it never returns. Can this be done by an Audi dealer? I don't have any interest in returning to the Audi dealer every 10,000miles for them to reset it. Also, since this light can not be reset by the owner without special equipment, and since the owner is under no obligation to either have service performed at an Audi dealer or buy this special equipment, shouldn't this issue be considered a vehicle defect for which Audi is responsible for rectifying?
Ganny, welcome aboard!
You're going to try to hold someone "at fault" for providing a service reminder ![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
I've re-programmed my service and oil change reminders a bit using the VCDS interface. I don't know if you could change the service interval to 9999 days, for example. The system may not accept it. Find you local VCDS person and have them try.
Thanks!
You're going to try to hold someone "at fault" for providing a service reminder![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
Yes, I find it to be a major defect that the service reminder can not be reset in the MMI (just like the oil change reminder).
Thanks!
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Why bother? The Ross-Tech VCDS cable and software license is only $350 and pretty much mandatory for any DIY work. If for no other reason than run a full scan once in a while to look for problems.
Doesn't that cable and software require a PC? I have no interest in buying a PC and a Cable just to reset a service due light. I'm not sure what other DIY work would be precluded without the VCDS, but if I do need a VCDS to perform that other DIY work then I would also have the same objection (the functionality to do ordinary maintenance and repairs should be built-in).
Then I'd strongly recommend the VAGCOM cable. If you're a DIY'er, it's worth the money, and it can easily be sold when you sell the call, or kept for your next VAG vehicle.
I'm still perplexed how this design issue could be deemed acceptable by anyone. If Audi does not disclose to buyers (before the purchase) that they will be unable to perform routine service without a trip to an Audi dealer (along with written proof of service) to reset the service light, then in those cases Audi should provide owners the necessary equipment or fix the design defect.
