Pop Up Camper Towing
#11
Lemme know what you come up with on the Q5 TDI and Trailer combination. I've almost talked myself back into dropping quite a bit more for the Merc M350 BluTec. It's a lot more towing capacity, but also alot more money and less my style I think. I'm coming from an FX35 that I'm absolutely delighted with...other than the (no) tow rating
Cheers,
Chance
Cheers,
Chance
#12
Sorry, don't own a VAG yet. But yes, unibodies as a rule can't handle the torque force like a true body-on-frame. Because of that, manufacturers will just say no to WDHs and categorically deny the warranty for anyone who uses them. One could look into Timbren overload springs or rear air shocks. Then at least it won't sag in the back.
#13
What is WDH??
Oohh it the bandage over the root cause, the excessive tongue load caused by the trailer axle location.
Any VAG owner knows that NO WDH on Q5, Touareg or Q7 as these are unibody vehicles without ladder frame and the trunk rear wall structure where hitch mounts is not designed to handle the torsion forces the WDH causes.
just curious , are the Q5,Q7 and touareg cars you get in the USA are they all only air suspension spec cars or do you also get the coil sprung versions as well. the 7 seat Q7 in Australia can tow 3200kg and has a tow ball weight limit of 300kg. i dont consider this excessive since that is what the factory nominate and you would think that it would be a conservative figure on there part.the 5 seat Q7 can tow 3500kg since you dont have to allow for the weight of 2 extra passengers. i,d like to see 2 x 150 kg guys sitting in the 2 rear seats.
#14
i was under the impression that the WDH (weight distribution hitches)only distributes the weight more evenly to the front wheels to prevent the back down nose up type of towing style which is dangerous. cars that do have the auto levelling suspension do not require this because the car can level itself.i know of cars (toyota landcruisers)that have the auto levelling initially had WDH applied but the onboard computer was fighting against the WDH which ended up burning out the computer. Just as an exercise i travelled without WDH and found it very light on the front end and steering, which made me very nervous, but once the car was level it changes the whole attitude of the rig.I tow with a monocoque chassis with 180kg on the ball.
And FWIW the OP, CGermany, ended up buying a Porsche Cayenne diesel with its 7716# tow rating. Opened up a lot more RVs for him vs towing with a Q5.
Bada Bing
A4 (B8 Platform) Discussion
75
12-30-2007 12:41 AM
Bada Bing
A4 (B7 Platform) Discussion
111
02-16-2007 06:57 AM
Bada Bing
02-20-2006 05:00 PM
