Problem with Xenon
Old 11-04-2012, 10:13 AM
migsan's Avatar
Default Problem with Xenon
Hello!
Anyone have any issue with the xenon or the control unit for the xenon bulbs?
Since last Friday, for 4 times, my left xenon turn off (Just the beam, the DRL still on) when I'm driving and I got the warning for burning light.
If I turn the car off, and tun on it light up again!
I see on vag-com an I have this error on 9 - Central Electrics:
00978 - Lamp for Low Beam; Left (M29)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 158
Reset counter: 9
Mileage: 80672 km
Time Indication: 0
Date: 2012.11.02
Time: 20:26:00
I Think could be the control unit on the left headlight... I this continue, I will trade the booth control units to see if the problem remain, and goes to the right side.
BTW,
Anyone can explain me these:
Fault Priority: 2
Reset counter: 9
The reset counter is the number of times that this occurs????
Old 11-04-2012, 10:34 AM
spijun's Avatar
Here you have the answer:
http://wiki.ross-tech.com/wiki/index.php/00978
Old 11-04-2012, 11:08 AM
migsan's Avatar
Originally Posted by spijun
Thanks spijun. I have already read that. I will see how it works in next days...
Old 11-04-2012, 01:38 PM
migsan's Avatar
About the meaning of the Fault Priority, Fault Frequency and Reset counter, I found it at: http://www.ross-tech.com/vcds/tour/dtc_screen.html
Old 11-04-2012, 09:13 PM
oaktreelimb's Avatar
Most likely the xenon bulb is bad. You can swap left and right bulbs and re check.
Old 11-05-2012, 01:48 AM
migsan's Avatar
My first thought is for the control unit of the xenon.
When I got some time I will swap the control units and see how it works, if the problem persist and goes to the other headlight...
Jan_PL_S6
12
11-27-2015 07:27 AM
alin.zalau
Q7 MK 1 Discussion
09-12-2015 01:09 PM
Christina Wong
09-11-2015 09:43 PM
audijess1972
09-09-2015 09:14 AM
Beena
A4 (B8 Platform) Discussion
09-02-2015 12:01 AM
Quick Reply: Problem with Xenon
