Last edit by: IB Advertising
- Audi Q5 Transmission Problem Diagnostic Guide<br>Guide to diagnose trouble and recommended solutions.
Q5 Brakes and transmission problems
I bought new 2011 Audi Q5 in Feb 2011 less than 6000 miles on OD. Last friday I parked it on a slope at the grocery shop's parking lot. After I put in reverse it starts to roll backwards and the car lost brakes, Even if the geared were changed to park position the car kept rolling backwards and I hit the curb. Luckily no other car was involved and no one got hurt. But I had my 2 yr old son in the car. What if this happened on a highway or if anyone got hurt?
The dashboard light lite up and the EPC light lite up while I was trying to stop the car. I hit the curb while still in parking gear. And the car just stole on me. It locked itself and I could not even get the keys out.
After the Towing guy came in, he was able to start the car and change the gear, in order to pull the car up on his flatbed, since it was not drivable.
I think the transmission has a glitch, I have read other forums with transmission problems and that it needed upgrades of software. I think the car did not engage in the park gear and it kept rolling backwards.
What if this happens again?
Did anyone else experience this?
Well, the dealer says there is no prblem with the car, they ran the diagnostics and everything seems fine. But they don't know what that EPC light means and why did that lite up.
I dont get it how come they don't know things about their own car.....
I need support to fight this.
Sounds very strange!
From what you have described I'd guess that you didn't have the engine running at the time and that you had no vacuum left in your brake booster hence unable to apply the brakes.
If you were rolling backwards at a reasonable clip when you moved the shifter to "P" then the transmission would not engauge park otherwise it would damage the transmission.
The other reason could be that there is a vacuum leak in the brake booster and hence unable to effectively apply the brakes.
Clearly it is a dangerous situation and you need to be sure there is nothing wrong with the car.
If you ever experience it again then:
I really hope you get this sorted out quick smart.
- Was the engine running at the time?
- How fast were you going when you moved the shifter to "P"?
- Push the brake pedal with ALL your strength - the brakes will work but they just require a lot of force to work.
- Apply the handbrake.
Definitely contact AoA (http://www.audiusa.com/us/brand/en/a...tact_audi.html) and not only tell them about the problem, but also make sure to stress how scary/dangerous it was, and that your dealership didn't seem to care...
Q52011hp, first let me say sorry to see you are having problems. Please clarify whether the engine was running or not.
Also as you were clearly on a hill why did you not engage the parking brake. The whole point of the parking brake is enable you to shift in and out of PARK without the load on the shifter. It also prevents runaways that are not parked in PARK!
It seems incredible that you are surprised by a car going backwards in reverse so we must be missing some details here.
Is it possbile that you somehow thought it was going to prevent the car from moving like a manual or stick shift might with its engine off (old persons training).
What little you have posted could only be described as sensationalist. I really suspect you have not given us all the details or you do not fully understand what was happening. This is further borne out by the service dept not finding a fault or fault code at least.
Is it possible that you had the shifter partially between reverse and park?
I am just repeating most of what has been said. I completely support Crustynoodle's reply.
Guys there is no need to chip in with remarks like "sell it" If there is a problem we dont need another owner coming back with the same story... then we will think there are two such problems. Anyway we have not as yet eliminated driver error, in which case "sell it" is no help either.... as we may find Q52011hp back again with the same problem with her next car.
Ok now about the details on that day. I cannot be 100% sure that the car was running, thats 1 thing that keeps bugging me, that i put the key in but did not actually press it when I changed the shifter in reverse. Having said that, once it was on a backward roll, i did press brakes, then I tried to stop it by changing shifter to P, even that did not work, I looked at the dash board, thinking that " am I hitting the accelerator", at this point I loosen my strength from the brake, and I looked at the rpm which was very close to 0, I cannot say if it was at 5 or not, and at this point it is also when I saw the EPC light come-up. I changed the gear in drive to see if I can move any forward that did not help either, I changed it back to P and looked back, steering to avoid hitting anyone else. That was the last thought I Had, was not to hit anyone. And as you can probably see, I had about 30-40 sec to react, and I did whatever I could at that point.
The 1 thing I missed is the hand brake, but Audi Q52011, has a digital park hand brake, I am not sure if this information of brake being digital is helpful or not.
Again i tahnk you for your time and effort. Let me Know that after knowing more do you think of anything else about the car or Driver error.
