Q5 headlight adjustment
Does anybody know if I need a VAG COM to adjust my low beam. The driver side of my low beam is higher then the other side. I see a screw right on top of thr head light housing, do I need to program in the adjustment after I adjust the screw like other Audi?
Thanks
Thanks
As far as I know, leveling system should be locked to service position with vag-com and after that manually adjust up or down, once manual done, service position needs to be released with cag-com.
I have to check this out and where is the service setting once I get home....
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
So I had to go and fiddle my lights and actually adjusted 1/4" higher just to see how adjustment works.
It needs VAG-COM -> Xenon Range -> Basic Settings -> from drop down window choose "adjustment pos...." and click once "on-off-next" button and dash will show adjustment system error and vag-com shows adjust lights -> turn lights on, pop the hood, lights have two adjusting screws, the one that haves cover is sideways so it's not needed (in most cases) and the one that shows Phillips head is up and down, screw either way -> back to computer and again click once "on-off-next" button and window shows "learnt....." and dash error goes off (if not the click the "on-off-next" button again) -> lights off -> power off and close the hood and you are done
![](https://i217.photobucket.com/albums/cc171/muddygsa/Audi/HIDadjustment.jpg)
No, I have original ross-tech USB cable (that time cried long cry shedding that amount of bucks but now afterwards I'm happy I did buy the thingie..)
03, adjust, adjustements, adjustment, audi, cable, head, headlight, headlights, healdight, lights, manually, q5, vag, vagcom
