Q5 Passenger Side Mirror Question
Hi fellow Audi owners!
I have a newly (4 month old) purchased Audi Q5 with a strange problem. Since I have owned the car I have had about 5 instances where the following happens.
I will park the car...at various inside and outside locations, When I return to the car just as I pull away I will notice that the driver's side mirror is tilted toward the ground. This is a very sporadic problem that never occurs to the passenger side mirror. The auto-folding mechanism appears to work great on both mirrors and I have never noticed any issues with positioning either mirror using the power controls. I typically keep the mirror switch on the inside pointed toward the passenger mirror.
I stopped by my local Audi dealer and had them take a quick look, but they could not come up with this being related to user error or mechanical problem. When I have my first service I will address this problem with the dealer again...but I wanted to see if any fellow Audi owners may have encountered this problem.
Thanks!!
Thanks!!
Club AutoUnion
Sounds to me like you are referring to the passenger side tilt feature. If you have the mirror adjuster switch selected to the passenger mirror, when you put your Q into reverse, the mirror will tilt down to show you your back right tire in relation to a curb. The feature is mostly useful when parallel parking so you don't get road rash on your back right wheel. When you put the car back into drive and start to drive away, the mirror should go back to its original position. If you do not like this feature and want it to stop, just turn your mirror selector switch onto the drivers mirror and leave it there instead.
Thank you for the quick reply! I typically have the mirror selector switch in the passenger mirror position because I do like the feature where the PASSENGER mirror tilts when placing the vehicle in reverse. However, the problem that I am encountering is with the DRIVER's SIDE mirror only. I have no issues with the passenger side mirror operation. Regardless to the position that I place the mirror selector switch, this problem with the driver's side mirror will occur. Unfortunately it appears to happen randomly with no easily recognizable sequence of events.
Again...thank you very much for the quick reply!!
Club AutoUnion
Hi,
Sometimes my key memory is out of sync with the memory setting assigned with the #1 and #2 memory buttons. When that happens I press my memory setting button and everything returns to proper setting.
Great suggestions...and thanks for correcting the typo in the title of my post. This is indeed a Driver's side mirror issue. In answer to everyone's questions:
1) I am the only driver
2) I only use key fob #1
3) The first time this happened I noticed it pulling out of my garage. Also...I have never noticed any finger prints on the mirror.
4) Checked stored seating/mirror settings...#1 and #2. and only #1 is set
I wish it happened regularly...but it is very sporadic....in the few months that I have had the car it has happened a total of 6 times. These are all great suggestions...thanks so much for everyone's thoughts!!
OP,
You are not alone. It happened twice to me today during a short period of time. We just picked up our new Q5 yesterday. I was getting familiar with the vehicle and was trying out the passenger mirror tiltdown feature when I noticed that it happened during a couple of quick stops while doing errands. It didn't happen at all yesterday while stopping a few times for refreshment on the long drive home. I tried to duplicate it in the driveway after I got home but it wouldn't take the bait.
My guess is that it's related to the switch and being in the passenger side position and maybe there's just something that sends the same signal to the driver's mirror simultaneously.
I'm going to continue to watch it...
Stephen Kormilo
10
03-20-2004 07:21 AM
roofman
10
09-26-2002 10:50 PM
thinkpad
08-18-2002 09:31 PM
Romeo
03-19-2001 05:09 PM
