Q5 Steering Defective Do Not Drive....HELP?
I’ve had a week of hell, seems like everything broke, and now my wife’s Q5 is not working for her.
The car displays “steering defective do not drive”
I thought it was a battery issue, and jumpstarted it and everything was good.
We replaced the battery and I thought the problem was solved.
Then it happened again, I was able to jump start it again but now I don’t know what is going on. Here are the error codes, thanks to my vag-com.
Any help on to where to start would help a lot.
4527 - Coolant Fan Control Circuit 1
P0480 00 [032] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 9
Mileage: 37285 km
Date: 2020.01.17
Time: 11:45:55
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 97 °C
Intake air temperature: 17 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.661 V
Unlearning counter according OBD: 38
CAN status - engine control module-Bits 0-7: 0
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
4531 - Fan 1 Control Circuit
P0691 00 [032] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 37285 km
Date: 2020.01.17
Time: 11:46:23
Intake air temperature: 18 °C
Voltage terminal 30: 12.015 V
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 37285 km
Date: 2020.01.17
Time: 11:45:55
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
4629 - ECM Power Relay Load Circuit
P068A 00 [040] - Opens Too Early
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Vehicle speed: 255 km/h
Coolant temperature: 15 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.156 V
Unlearning counter according OBD: 40
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 0000 0100
2 Faults Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 7
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:45:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0702
Hex Value: 0x120C
Hex Value: 0xE397
Hex Value: 0x0000
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 12:02:00
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x0015
Hex Value: 0x1094
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:46:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:45:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:45:56
Freeze Frame:
Bin. Bits: 10011
Voltage: 12.10 V
Count: 6
Bin. Bits: 10000
Time: 0.40 s
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:47:02
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.10 V
Count: 6
Bin. Bits: 10000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 37285 km
Date: 2020.01.17
Time: 11:45:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 37285 km
Date: 2020.01.17
Time: 11:46:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 37285 km
Date: 2020.01.17
Time: 11:45:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:45:55
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0702
Hex Value: 0x120C
Hex Value: 0xE397
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 12:02:00
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x0015
Hex Value: 0x1094
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:46:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:45:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:45:56
Freeze Frame:
Bin. Bits: 10011
Voltage: 12.10 V
Count: 6
Bin. Bits: 10000
Time: 0.40 s
02252 - Generator
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 252
Mileage: 37285 km
Time Indication: 0
Date: 2020.01.17
Time: 11:47:02
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.10 V
Count: 6
Bin. Bits: 10000
Hello,
This just happened to me last night and you may want to look at these threads as well:
I plan on filing a complaint once I have more information.
- https://www.audiworld.com/forums/q5-...ilure-2896481/
- https://www.audiworld.com/forums/q5-...ilure-2972881/
Audi replaced the steering module (as I recall, it was the same part number). The problem has not reappeared, currently at about 17k miles.
Have not received any response from NHTSA about this safety complain, perhaps filing another complaint and referencing this one might help: https://www.nhtsa.gov/recalls?nhtsaId=11209594
Perhaps reaching out to Audi America, reference my problem as well as the similar issues in previous model years will get them to take the steering problem more seriously.
Reimbursement
Just had this happen to me. Currently in the shop being fixed. Around $3900 like most people have said. I did receive the extended warranty letter back in June 2021 and even attached that as evidence in my reimbursement submission. Just received an email back from Audi saying that repairs had to be completed BEFORE June 2021. Is this correct? My vehicle is still under the extended warranty limits so I have a hard time believing this. What's the point of the extended warranty then?
What year is your vehicle and what mileage? Did you read the letter that spijun posted a link of above? It has the letter in PDF format and says 10 years or 125,000 miles from the vehicles original in service date. What is the year and/or manufacturer date of your vehicle?
https://www.audiworld.com/forums/q5-...etter-3020585/
2014 and 88,000. That's the exact same letter I received. That's sort of my question. My vehicle is clearly within the parameters of the extended warranty so why would someone from Audi tell me any repairs needed to be completed before June 2021?
I don't know, you should push Audi to answer that question for you. I have a 2014 also and it was manufactured in 02/14, some may have been made in late 2013. I would ask them to answer the question or call Audi of America if you don't feel like you're getting the answers you deserve. You should be under warranty as far as I understand it.
