q5 third brake light out
You need this 8R0-945-097
http://www.jimellisaudiparts.com/pro...8R0945097.html
A lot of work but if you decide this is the procedure:
![Name: ScreenShot262_zpsaea784d1.jpg
Size: 32.2 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78660d1501278755-q5-third-brake-light-out-screenshot262_zpsaea784d1.jpg)
![Name: Clipboard_zpsbc4c4404.jpg
Size: 67.5 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78661d1501278755-q5-third-brake-light-out-clipboard_zpsbc4c4404.jpg)
![Name: ScreenShot260_zps6c4ca75f.jpg
Size: 55.3 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78662d1501278755-q5-third-brake-light-out-screenshot260_zps6c4ca75f.jpg)
![Name: ScreenShot261_zps44d737a8.jpg
Size: 58.6 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78663d1501278755-q5-third-brake-light-out-screenshot261_zps44d737a8.jpg)
FYI, to get the top trim off of the hatch you have to take the bottom trim off first. There are 4 screws behind the light panels and that center compartment. From there it is held in place with clips. It's a pain to get off without some kind of pry tool. So is the connector for the open/close button.
![Name: ScreenShot265_zpsa050056c.jpg
Size: 95.5 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78657d1501278737-q5-third-brake-light-out-screenshot265_zpsa050056c.jpg)
![Name: Clipboard_zps235bd7f5.jpg
Size: 67.3 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78658d1501278737-q5-third-brake-light-out-clipboard_zps235bd7f5.jpg)
![Name: ScreenShot269_zpsc4a03356.jpg
Size: 40.5 KB](https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/78659d1501278737-q5-third-brake-light-out-screenshot269_zpsc4a03356.jpg)
If Audi deigned with one screw in each side of the brake light lens would have taken less than 5 minutes to remove. Now you need to spend a few hours and probably break the clips, etc. trying to remove it. I just don't understand Audi engineering anymore compared to years ago.
I'd like to see the the dealer charge for this one......
I was actually surprised how well designed those clips are (they're metal). Everything is very well put together. If you break something then you were pulling the wrong way and too hard.
