Q5 Trailor Hitch - Installed and it looks great!
#12
The hitch looks good.
I still think that it is crazy to have to go through that much work to dismantle and cut into a brand new car to install a trailer hitch. And the cost is completely outrageous. Audi should have made the trailer hitch a standard option on the Q5. It would have made more sense to install them before installing the bumper and then they could have designed the bumper differently. I want a trailer hitch as well but refuse to pay that kind of money or tear up my new car.
I did not have to remove the bumper or cut the bumper.
#13
TTR2002:
Do you have pics of your install including electrical.
I only need a hitch to trailer 1-2 motorbikes on a very light trailer (which actually disassembles and fits in the trunk). While I understand that the OEM ECU+hitch includes connections for trailer brakes and what not, I think I would only miss the revised transmission/shifting that supposed to come with the OEM ECU.
#14
TTR2002:
#16
THANKS ttr2002, after looking at the site, reading the installation instructions and considering the price, I have orderd one too. I may have it professionally installed at a shop, but still saving $$$ compared to the Audi product and NO CUTTING required!
#17
You will need a half inch drill bit and drill, a grinder, and a cut off wheel to cut a nice square hole (I used my dremmel tool with a reinforced cut off wheel)
I had to modify the Curt hitch by elongating the aft horns holes and rounding off the corners on the aft horn to make it easier to fit.
I cut a 1 inch sq hole on the front part of the Q5 frame rail to fish in the carriage bolt and sq plate. I will warn you. You will need to grind the middle carriage bolts on the head to a width of 3/4 inch to have it fit in the aluminum bumper sq channel (same for the metal plate. If you like I can email you photos or even call you. This will save you or your shop hours of trying to fish the bolt in the middle frame.
#18
I installed it myself and took about 4 hours because I had to lower and remove that back half of the exhaust.
#19
Hungs too low for me and anyways, I rather cut the plastic bumper than any steel or alu part of car....
My hitch is waiting at dealer and will pick it up and install it next weekend
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
#20
Well my labor was free. I would bet a shop could install in 2-3 hrs at a normal rate of $50/hr. The Audi dealer rate is $105/hr. I did not need any extra parts for the curt hitch. I will consider the Audi control tail light box when my dealer gets me the information. I think both hitches are good, for me I just wanted the hitch for my bike rack and $200 was a good value for me.
