Q5 Wheels Questions
The answer to your question is dependent on the specific specs of the wheels you are looking at. Some may fit, others may not. I'm running S7 wheels on my SQ5. But the tires will likely need to be higher profile in order to match the size needed for your speedo, else I'd think you'd be way off.
Online Wheel and Tyre Fitment Calculator
For the Q5, you can run a more aggressive offset than the setup you are considering. I ran a 20x9 et30 setup for a while and thought it could have used spacers. And there's plenty of sets that come up for sale in the classifieds that will have the correct sized tires and look better overall.
The wheels will fit but the tires will be too short. You can try using willtheyfit.com to compare to other setups. I plugged in a pretty wide and aggressive setup someone else is running as a comparison point.
You can start here to see what other people are running: The Official Q5/SQ5 Wheel Thread - Post your setup!
I like the "beefier" look (not sure if thats the right term), I like the look of bigger wheels. I asked the Audi dealership about ordering 20" but it was way too pricey for me. This is a lease so I am not looking to spend too much... but thank you I'll check out that forum. If you have any suggestions, send them my way, I have been looking around but just do not know enough about wheels.
Thank you!
Thank you!
Thank you!
Thank you!
http://europrice.us/wheels/stasis-wheels
Chinh9vu
05-20-2019 01:52 PM
