Question for the B&O Folks..
#21
I may go on the "naughty list" but I think we're putting way too much thought into the sound system. I love the B&O and I love my music. The B&O sounded great from the first song I played and with every track since then. No regrets. I really don't know what else to say other than it is your choice whether or not to get it with your Audi.
#22
#23
I think it's all about exposure. Everyone thought their first car was fast too. It's easy to be happy with mediocrity if you haven't experienced excellence.
Some people aren't audiophiles, and some just want background noise. If the money is worth it to you that's fine, but my argument has been, and will continue to be, that B&O isn't good. It IS better than the base audio, however.
#24
#25
I can certainly agree with that, it really depends on what you are compare speed or sound quality with. The B&O system in the last gen A8 was much better than the B&O in the Q5, but at 10 times the cost. I also had a Mark Levison system on a Lexus GX470 that sounded pretty good. Of course, none of these system will sound good when compare to a high quality aftermarket audio system.
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
#26
Absolutely agree that the sound quality is good
I was disappointed strength or loudness. B&O system is 505W and the Audi sound system with 180W, which is at maximum 30% louder than the B & O system?????? Who does not believe a comparable audio systems.
How is it possible that the Audio sound system with 180W louder than the B & O from 505W ?????
#27
I will disagree, not because I think you're wrong, but because, unless you're listening in an anchoic chamber, every environment will have ambient noise. It can be compensated for in a car, as it can in a home. It will take a LOT more EQ, but it can be done, to the point that it's mostly, not totally, a non-issue.
#28
#29
Not sure what your getting at here.. "Good" is about as subjective as it gets. It's not measurable, unless you want to count smiles and thumbs up. Everybody's taste is different. An audio purist wants accuracy. My kids like enhanced bass. Rappers like ridiculously enhanced and thumping lower bass. And so it goes.
Are you confusing EQ with noise canceling? For example, if you have a 3KHz noise source, EQ-ing the sound coming out of the stereo speakers isn't going to silence it but noise-canceling might. Theoretically, sophisticated feedback-driven noise-canceling might be able to overcome the constantly changing background noise in a car but not on a practical basis, at least not yet. Most listeners simply turn up the volume so high that the signal overwhelms the ambient noise. They think, "Hmm, it sounds "better" turned up, I can hear details better." What the listener has done is drowned out the background noise (increased S/N).
I do agree about drowning out the road noise. Really, that's all we're ever doing in any environment, including in the home.
I can't WAIT for the day when DSP can truly compensate for road noise. Either that or cars finally are quiet enough for it to be a non-issue.
#30
I am not sure if I agree with that. The B&O system can play louder music without distortion when compare to the Audi system, but you are right, the hugh difference in wattage doesnt reflect the difference between the two system as far as loudness. For example, the Bose system in the A6 has only 255 watts and it sounds better and louder than the B&O system in the Q5 which has 505 watts.
Another problem could be the crossover settings. If the sub to midbass transition is too high and you have a weak sub you'll run into the same problem. The perception of volume comes from the midbass region and when that's weak people will keep turningi it up and up and up and it will sound bad.
As I've already said, I'm a power *****. I LOVE to really get on it and I've never needed more than 150 Watts on my tweeters and mids, but I will tend to at least double that to my midbasses and I've gone as high as 500 Watts per midbass. For the sub it will depend on the number, size, efficiency, and enclosure type. I've never needed more than 1000 Watts total on my subs. Having said all that, this setup, even using horribly inefficient Dynaudio drivers, got STUPID loud. You could cut that by 2/3 and still be pretty damned loud.
I think B&O made some mistakes with this system. And that sucks because they were nice enough to toss 8s in the doors but then they used odd-sized mids making upgrades difficult. I think some Dayton RS100s will fit in the OEM locations. A much larger mid in the center channel would have kicked ***.
