Question regarding the 20" RS5 wheels
Does anyone know if the 20" rs5 wheels will fit the q5? i did a quick search and couldn't find anything. I seen the replica's that look like these, however they aren't offered in the 20". I attached the pic of the wheels i was interested in.
They should, as the bore/offset from the A5/S5 work (I can't imagine Audi changes that specifically for the RS5).
Do you know the width, offset, and centerbore of the wheels?
-tgt
-tgt
If they're OEM wheels, the bolt pattern and center bore should be the same. The offset will most certainly be more aggressive than the standard Q5's offset, but will likely be OK. Are you buying from a dealer or a private seller? I'm only curious because I would expect a dealer to know.
Thanks for the help guys. I haven't talked to a dealer as I wanted to explore buying them online first. Either way they look to be 3k or more. I wouldnt mind buying decent replicas but so far I haven't found any 20's.
Never Follows
There was a guy on the RS6 forum selling them but not sure if he is reputable.
http://www.rs6.com/showthread.php/22523-FS-Original-Audi-RS5-wheels-9Jx20-ET26-Titan-PICS!
