Rear View Camera Turn Off Speed
Has anyone used VCDS to change the turn-off speed of the rear-view camera? Once the Q5 is put in Drive after reverse, the camera stays on until the speed reaches 6+ mph. I'd like it to turn off when placed in Drive or at least sooner than 6 mph. I found in a forum the following information, however modual-(10) park/steer does not exist in my 2013 Q5.
"If you want to make the rear view camera instantly go off upon a gear shift to drive here is the vag-com coding. This will make the rear view camera instantly turn off as well as bring up a car and sensor graphic:
10 - Park/Steer Assist
16 security access ---> 71679
Do it!
7-coding
Byte 0
Bit 4 change 0 to 1"
and this one
"If you only want to change the turn-off speed of the rear-view camera, you can always use this:
Audi parking system - Switch OFF Speed in MMI:
Adaptation - 10 --> Channel 23
change 10 to (5 through 20 kmh) 5kmh = 3 mph"
Also, has anyone ever contacted VAG-COM for assistance with modifications/problems?
Do it!
7-coding
Byte 0
and this one
Do it!
7-coding
Byte 0
and this one
Do it!
7-coding
Byte 0
and this one
Select 10 - Park/Steer Assist
[Adaptation - 10]
Channel 23 (channel 233 with facelift) adjusting the value as desired. Maximum value of 20 (Equivalent value km / h)
VAG-COM???? It does not exist for a long time
Maybe you think the Ross-Tech
For SQ5 the parking aid control unit is integrated in the vehicle electrical system. Channel not yet known to adapt
Try this:
[Adaptation - 10]
[Adaptation - 10]
Thanks though...
tunes
S4 (B8 Platform) Discussion
07-09-2011 05:30 AM
Tom (90Carat)
Audi Original "S" Cars
11-27-2007 12:52 PM
