Remote Start(?)
How difficult is it to implement starting the Q5 remotely? If you had purchased the smart key option, it would seem remote start is only a nickel away from being a reality(?)
It's snowing again here on the Avalon![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
TIA
TIA
This has been asked many times on here, but I've only seen 1 person who's successfully installed one. He used a high-end electronics shop. I'll take a stab at this and ask why would the smart key option make it easier to install remote start? A remote starter generally relies on the installation of a physical key, but our cylinders are electronic start. Before you even begin to think about installing a remote starter, you need to bypass the electronic start somehow. Maybe replace your key cylinder with an aftermarket one? I don't know if they make a key cylinder bypass for our cars. If they don't, then we're talking about a $1000 part. If they do, then it should only cost about $100 for the bypass plus maybe $50-100 for an immobilizer, lock and alarm bypass. Plus the cost of the remote start which can run anywhere from $100-1000. Plus labor if you can't do this yourself which I'm assuming you can't based on your question. So it can be done, but not for a nickel! So if you can find a key cylinder bypass for the Q5 and you don't mind having a cheap starter (i.e. carrying a cheap-looking Key FOB in addition to your Audi key), then I'm going to guess around $700 installed if you can find a good shop to do it for you. Otherwise, around $1000-$1200 installed for a higher-end Viper system.
I would not do that because of possible problems with electronics and protection system that has installed by Audi, which must be removed to install the remote start
Here is the guy I was thinking of who got it installed on his Q5:
https://www.audiworld.com/forums/sho...remote+starter
So I did some searching and found this:
http://www.xpresskit.com/product.aspx?productid=461
Use that as your interface module.
You'll also need a XKLoader2 to program the module:
http://www.xpresskit.com/product.aspx?productid=422
Also use this to bypass your key:
http://www.sonicelectronix.com/item_...U-B-556UW.html
You will lose your spare key since you need to tear it apart to get the physical key out of the plastic housing.
Then you can pick any remote starter you want. May I suggest this one which can be activated from your smartphone:
http://www.bestbuy.com/site/Viper---...&skuId=9516348
I think that's all you need, but if anyone sees that I missed anything please chime in.
That's what all the bypass modules are for. The car works fine when your car is parked or when you are driving, but those electronic systems you mention are temporarily bypassed when you go through the remote start routine.
All new Audi models since 2008 have a system of protection in 5 points.
Audi's ignition system in five points (five processors) and if it does not coincide simultaneously all ignition the engine is automatically blocked.
Plus potential problems if it did not orignal electronics equipment
Not to say that it is not possible to install but it is possible to lose your factory warranty on electronics, which could be costly
I wasn't thinking about a 3rd party implimentation as easy or cheap ... Rather, thinking if Audi could implement a start button in close proximity of a smart fob, then it should be easy to add a start button to the fob for when it's in close proximity(?) just a thought
andersonus
12-17-2015 11:19 AM
arizona steve
05-04-2006 06:29 AM
